sameer.al-obaidi
Vivado and HDL coder
Hi;
I got the warning message as in attach the file when to convert from Matlab HDL coder to Vivado .xpr project. How can I make it work with Vivado 2015.4
Note: using windows 10.
u4223374
Advisor
Advisor
It's a warning, not an error - so you can ignore it and see what happens. Otherwise, the "solution" is to install a version of Vivado that is supported (eg. 2014.2). You can have both Vivado 2014.2 and Vivado 2015.4.1 installed at the same time.
u4223374
Advisor
Advisor
arpansur
Hi @sameer.al-obaidi,
Windows10 is not supported with Vivado2015.4. Please go through page-14 of following link for more information on supported OS.
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2015_4/ug973-vivado-release-notes-install-license.pdf
Arpan
Arpan
sameer.al-obaidi
Thanks, so can I install virtual machine in win10  includes win-7
Teddy
Which version of HDL coder is compatible with Vivado 2020.2?
Thank you,
Teddy
