09-27-2014 03:48 AM
Consider the following (slightly over-complicated) test case:
module issue_057(a, y);
input [2:0] a;
output [3:0] y;
localparam [5:15] p = 51681708;
assign y = p[15 + a -: 5];
endmodule
This is expected to set **y[3]=1** for **a=1**, but the vivado 2014.2 synthesis output sets **y[3]=0**.
Crosscheck: Verific 35_463_32_140722, Modelsim 10.1e, XSim 2014.2 and Icarus Verilog (git 1572dcd) implement this correctly. Quartus 14.0 suffers from the same bug. (XST 14.7 also suffers from the bug.)
09-27-2014 05:43 AM
09-27-2014 07:03 AM
> I would check if out of bounds starting points are legal LRM wise. If not, then there may not be a right answer.
Of course I did check with the LRM _before_ making my post.
See sec. 5.2.1. of IEEE Std. 1364-2005:
Part-selects that are partially out of range shall, when read, return x for the bits that are out of range and shall, when written, only affect the bits that are in range.
(IEEE Std. 1800-2012 has exactly the same wording in sec. 11.5.1.)
The important part here is of course "for the bits that are out of range".
> But the localparam size and value could be tweaked so that all values of "a" are in bounds. Maybe like: localparam [ 5:15+7] p = { xyz, 7'd0 }
I used to add "Note: This is a bug report. I don't need support." to the bottom of my bug reports. I forgot it this time, so I guess I am to blame for getting this kind of replies..
09-27-2014 08:00 AM
I getcha.. It's hard to know the context of a post sometimes.
At any rate, it's funny that all the synthesizers behaved differently than all the simulators.
Pretty nasty bug! Could cause a lot of lab head scratching..
