Visitor mdjacobs
Vivado crashes during synthesis (every time)
I have a rather large design targeting the VC707. I can snythesize every piece of the design separately. But the entire design together causes Vivado 2013.2 to crash, always. There is no error message other than synthesis failed. I found a crash log file in the runs directory. It's pasted below.
The issue seems to be one of total design size. Adding up the constituant parts suggests the entire design is about 60-70% of the total device utilization. But the best I can do is synthesize a chunk of the design that uses up to 54% of the device. Adding any more of the design causes synthesis to fail.
I'm running on Ubuntu 10.04 64 bit, using Vivado 2013.2. If you've seen this problem. Please let me know what the work around is.
hs_err_pid4693.log
# An unexpected error has occurred (11)
Stack:
/lib/libc.so.6(+0x33af0) [0x7fd634137af0]
/opt/Xilinx/Vivado/2013.2/lib/lnx64.o/librdi_synth.so(HARTNlCleanup::IsDrivingFlop(NInst)+0x83) [0x7fd61623dab3]
/opt/Xilinx/Vivado/2013.2/lib/lnx64.o/librdi_synth.so(HARTNlCleanup::demoteNonCriticalMuxF()+0x2c9) [0x7fd6162511e9]
/opt/Xilinx/Vivado/2013.2/lib/lnx64.o/librdi_synth.so(HARTNlCleanup::cleanup(char const*, UHashMap<UString, UHashMap<UString, UString, UString, UEKey<UString> >*, UString, UEKey<UString> >&, bool)+0x15f1) [0x7fd616270971]
/opt/Xilinx/Vivado/2013.2/lib/lnx64.o/librdi_synth.so(HARTNDb::cleanupNetlistBottomUp(NRealMod, UHashSet<UString, UString, UEKey<UString>, UHashSetNode<UString>, UString, UEValue<UString, UHashSetNode<UString> > >&, char const*, UHashMap<UString, UHashMap<UString, UString, UString, UEKey<UString> >*, UString, UEKey<UString> >&, UString, TTime)+0x14d) [0x7fd615f4bc9d]
/opt/Xilinx/Vivado/2013.2/lib/lnx64.o/librdi_synth.so(HARTNDb::cleanupNetlist(char const*)+0x1a2) [0x7fd615f59e22]
/opt/Xilinx/Vivado/2013.2/lib/lnx64.o/librdi_synth.so(+0x988111) [0x7fd615fc8111]
/opt/Xilinx/Vivado/2013.2/lib/lnx64.o/librdi_synth.so(+0x947b27) [0x7fd615f87b27]
/opt/Xilinx/Vivado/2013.2/lib/lnx64.o/libtcl8.5.so(+0x32cf7) [0x7fd630504cf7]
/opt/Xilinx/Vivado/2013.2/lib/lnx64.o/libtcl8.5.so(+0x3455b) [0x7fd63050655b]
/opt/Xilinx/Vivado/2013.2/lib/lnx64.o/libtcl8.5.so(TclEvalObjEx+0x11c) [0x7fd630506d3c]
/opt/Xilinx/Vivado/2013.2/lib/lnx64.o/libtcl8.5.so(+0x3aef1) [0x7fd63050cef1]
/opt/Xilinx/Vivado/2013.2/lib/lnx64.o/libtcl8.5.so(+0x732d3) [0x7fd6305452d3]
/opt/Xilinx/Vivado/2013.2/lib/lnx64.o/libtcl8.5.so(+0x7b3d1) [0x7fd63054d3d1]
/opt/Xilinx/Vivado/2013.2/lib/lnx64.o/libtcl8.5.so(TclEvalObjEx+0x196) [0x7fd630506db6]
/opt/Xilinx/Vivado/2013.2/lib/lnx64.o/librdi_commontasks.so(+0x20505c) [0x7fd62ca1a05c]
/opt/Xilinx/Vivado/2013.2/lib/lnx64.o/libtcl8.5.so(TclObjInterpProcCore+0x10b) [0x7fd63058707b]
/opt/Xilinx/Vivado/2013.2/lib/lnx64.o/libtcl8.5.so(Tcl_ExprObj+0x116) [0x7fd63054d5c6]
/opt/Xilinx/Vivado/2013.2/lib/lnx64.o/libtcl8.5.so(Tcl_ExprBooleanObj+0x1e) [0x7fd630505ade]
/opt/Xilinx/Vivado/2013.2/lib/lnx64.o/libtcl8.5.so(+0x3e3e4) [0x7fd6305103e4]
/opt/Xilinx/Vivado/2013.2/lib/lnx64.o/libtcl8.5.so(Tcl_FSEvalFileEx+0x21e) [0x7fd630569b8e]
/opt/Xilinx/Vivado/2013.2/lib/lnx64.o/librdi_commontasks.so(+0x2233af) [0x7fd62ca383af]
/opt/Xilinx/Vivado/2013.2/lib/lnx64.o/librdi_common.so(+0x4a449b) [0x7fd63520249b]
/opt/Xilinx/Vivado/2013.2/lib/lnx64.o/libtcl8.5.so(+0xb4aef) [0x7fd630586aef]
/opt/Xilinx/Vivado/2013.2/lib/lnx64.o/libtcl8.5.so(+0xaa8a5) [0x7fd63057c8a5]
/opt/Xilinx/Vivado/2013.2/lib/lnx64.o/libtcl8.5.so(+0x342ed) [0x7fd6305062ed]
/opt/Xilinx/Vivado/2013.2/lib/lnx64.o/libtcl8.5.so(Tcl_EvalObjv+0x48) [0x7fd630505278]
/opt/Xilinx/Vivado/2013.2/lib/lnx64.o/libtcl8.5.so(TclEvalObjEx+0x2f8) [0x7fd630506f18]
/opt/Xilinx/Vivado/2013.2/lib/lnx64.o/librdi_common.so(hdi::tcltasks::task_manager::eval_in_tcl(Tcl_Interp*, Tcl_Obj*, char const*, bool)+0xa01) [0x7fd6352011c1]
/opt/Xilinx/Vivado/2013.2/lib/lnx64.o/librdi_designutils.so(HRTInvoker::inProcessLaunch(HDGUIStatus&)+0x51d) [0x7fd623f5a1dd]
/opt/Xilinx/Vivado/2013.2/lib/lnx64.o/librdi_designutils.so(HRTInvoker::launch(HDGUIStatus&)+0x6b5) [0x7fd623f5b085]
/opt/Xilinx/Vivado/2013.2/lib/lnx64.o/librdi_vivadotasks.so(+0x1bfd71) [0x7fd61103dd71]
/opt/Xilinx/Vivado/2013.2/lib/lnx64.o/librdi_vivadotasks.so(+0x1c641d) [0x7fd61104441d]
/opt/Xilinx/Vivado/2013.2/lib/lnx64.o/librdi_commontasks.so(+0x246e40) [0x7fd62ca5be40]
/opt/Xilinx/Vivado/2013.2/lib/lnx64.o/librdi_commontasks.so(+0x24b790) [0x7fd62ca60790]
/opt/Xilinx/Vivado/2013.2/lib/lnx64.o/librdi_commontasks.so(+0x247f1c) [0x7fd62ca5cf1c]
/opt/Xilinx/Vivado/2013.2/lib/lnx64.o/librdi_commonmain.so(+0x6e04) [0x7fd634b57e04]
/opt/Xilinx/Vivado/2013.2/lib/lnx64.o/libtcl8.5.so(Tcl_Main+0x1d2) [0x7fd63056f562]
/opt/Xilinx/Vivado/2013.2/lib/lnx64.o/librdi_common.so(boost::function0<void>::operator()() const+0x1a) [0x7fd6352337ba]
/opt/Xilinx/Vivado/2013.2/lib/lnx64.o/librdi_common.so(+0x4d5799) [0x7fd635233799]
/lib/libpthread.so.0(+0x69ca) [0x7fd63448d9ca]
/lib/libc.so.6(clone+0x6d) [0x7fd6341ea70d]
Matt
Re: Vivado crashes during synthesis (every time)
Attach your runme.log from synth_1 folder to investigate the issue.
Also try running synthesis in a supported OS.
Participant jakubon2
Hi there.
I am experiencing the same problem running Vivado 2013.2 on Ubuntu 12.04 LTS for ZedBoard. I have attached the logs. Any progress on solving this issue? I tried to synthesise a part of my design without the processing system and it was successful.
Many thanks,
Ondrej
Stack:
/lib/x86_64-linux-gnu/libc.so.6(+0x364a0) [0x7ffbe77254a0]
/opt/Xilinx/Vivado/2013.2/lib/lnx64.o/librdi_synth.so(HARTNlCleanup::IsDrivingFlop(NInst)+0x83) [0x7ffbc966fab3]
/opt/Xilinx/Vivado/2013.2/lib/lnx64.o/librdi_synth.so(HARTNlCleanup::demoteNonCriticalMuxF()+0x2c9) [0x7ffbc96831e9]
/opt/Xilinx/Vivado/2013.2/lib/lnx64.o/librdi_synth.so(HARTNlCleanup::cleanup(char const*, UHashMap<UString, UHashMap<UString, UString, UString, UEKey<UString> >*, UString, UEKey<UString> >&, bool)+0x15f1) [0x7ffbc96a2971]
/opt/Xilinx/Vivado/2013.2/lib/lnx64.o/librdi_synth.so(HARTNDb::cleanupNetlistBottomUp(NRealMod, UHashSet<UString, UString, UEKey<UString>, UHashSetNode<UString>, UString, UEValue<UString, UHashSetNode<UString> > >&, char const*, UHashMap<UString, UHashMap<UString, UString, UString, UEKey<UString> >*, UString, UEKey<UString> >&, UString, TTime)+0x14d) [0x7ffbc937dc9d]
/opt/Xilinx/Vivado/2013.2/lib/lnx64.o/librdi_synth.so(HARTNDb::cleanupNetlist(char const*)+0x1a2) [0x7ffbc938be22]
/opt/Xilinx/Vivado/2013.2/lib/lnx64.o/librdi_synth.so(+0x988111) [0x7ffbc93fa111]
/opt/Xilinx/Vivado/2013.2/lib/lnx64.o/librdi_synth.so(+0x947b27) [0x7ffbc93b9b27]
/opt/Xilinx/Vivado/2013.2/lib/lnx64.o/libtcl8.5.so(+0x32cf7) [0x7ffbe3a76cf7]
/opt/Xilinx/Vivado/2013.2/lib/lnx64.o/libtcl8.5.so(+0x3455b) [0x7ffbe3a7855b]
/opt/Xilinx/Vivado/2013.2/lib/lnx64.o/libtcl8.5.so(TclEvalObjEx+0x11c) [0x7ffbe3a78d3c]
/opt/Xilinx/Vivado/2013.2/lib/lnx64.o/libtcl8.5.so(+0x3aef1) [0x7ffbe3a7eef1]
/opt/Xilinx/Vivado/2013.2/lib/lnx64.o/libtcl8.5.so(+0x732d3) [0x7ffbe3ab72d3]
/opt/Xilinx/Vivado/2013.2/lib/lnx64.o/libtcl8.5.so(+0x7b3d1) [0x7ffbe3abf3d1]
/opt/Xilinx/Vivado/2013.2/lib/lnx64.o/libtcl8.5.so(TclEvalObjEx+0x196) [0x7ffbe3a78db6]
/opt/Xilinx/Vivado/2013.2/lib/lnx64.o/librdi_commontasks.so(+0x20505c) [0x7ffbdf82e05c]
/opt/Xilinx/Vivado/2013.2/lib/lnx64.o/libtcl8.5.so(TclObjInterpProcCore+0x10b) [0x7ffbe3af907b]
/opt/Xilinx/Vivado/2013.2/lib/lnx64.o/libtcl8.5.so(Tcl_ExprObj+0x116) [0x7ffbe3abf5c6]
/opt/Xilinx/Vivado/2013.2/lib/lnx64.o/libtcl8.5.so(Tcl_ExprBooleanObj+0x1e) [0x7ffbe3a77ade]
/opt/Xilinx/Vivado/2013.2/lib/lnx64.o/libtcl8.5.so(+0x3e3e4) [0x7ffbe3a823e4]
/opt/Xilinx/Vivado/2013.2/lib/lnx64.o/libtcl8.5.so(Tcl_FSEvalFileEx+0x21e) [0x7ffbe3adbb8e]
/opt/Xilinx/Vivado/2013.2/lib/lnx64.o/librdi_commontasks.so(+0x2233af) [0x7ffbdf84c3af]
/opt/Xilinx/Vivado/2013.2/lib/lnx64.o/librdi_common.so(+0x4a449b) [0x7ffbe882a49b]
/opt/Xilinx/Vivado/2013.2/lib/lnx64.o/libtcl8.5.so(+0xb4aef) [0x7ffbe3af8aef]
/opt/Xilinx/Vivado/2013.2/lib/lnx64.o/libtcl8.5.so(+0xaa8a5) [0x7ffbe3aee8a5]
/opt/Xilinx/Vivado/2013.2/lib/lnx64.o/libtcl8.5.so(+0x342ed) [0x7ffbe3a782ed]
/opt/Xilinx/Vivado/2013.2/lib/lnx64.o/libtcl8.5.so(Tcl_EvalObjv+0x48) [0x7ffbe3a77278]
/opt/Xilinx/Vivado/2013.2/lib/lnx64.o/libtcl8.5.so(TclEvalObjEx+0x2f8) [0x7ffbe3a78f18]
/opt/Xilinx/Vivado/2013.2/lib/lnx64.o/librdi_common.so(hdi::tcltasks::task_manager::eval_in_tcl(Tcl_Interp*, Tcl_Obj*, char const*, bool)+0xa01) [0x7ffbe88291c1]
/opt/Xilinx/Vivado/2013.2/lib/lnx64.o/librdi_designutils.so(HRTInvoker::inProcessLaunch(HDGUIStatus&)+0x51d) [0x7ffbd738c1dd]
/opt/Xilinx/Vivado/2013.2/lib/lnx64.o/librdi_designutils.so(HRTInvoker::launch(HDGUIStatus&)+0x6b5) [0x7ffbd738d085]
/opt/Xilinx/Vivado/2013.2/lib/lnx64.o/librdi_vivadotasks.so(+0x1bfd71) [0x7ffbc446fd71]
/opt/Xilinx/Vivado/2013.2/lib/lnx64.o/librdi_vivadotasks.so(+0x1c641d) [0x7ffbc447641d]
/opt/Xilinx/Vivado/2013.2/lib/lnx64.o/librdi_commontasks.so(+0x246e40) [0x7ffbdf86fe40]
/opt/Xilinx/Vivado/2013.2/lib/lnx64.o/librdi_commontasks.so(+0x24b790) [0x7ffbdf874790]
/opt/Xilinx/Vivado/2013.2/lib/lnx64.o/librdi_commontasks.so(+0x247f1c) [0x7ffbdf870f1c]
/opt/Xilinx/Vivado/2013.2/lib/lnx64.o/librdi_commonmain.so(+0x6e04) [0x7ffbe817fe04]
/opt/Xilinx/Vivado/2013.2/lib/lnx64.o/libtcl8.5.so(Tcl_Main+0x1d2) [0x7ffbe3ae1562]
/opt/Xilinx/Vivado/2013.2/lib/lnx64.o/librdi_common.so(boost::function0<void>::operator()() const+0x1a) [0x7ffbe885b7ba]
/opt/Xilinx/Vivado/2013.2/lib/lnx64.o/librdi_common.so(+0x4d5799) [0x7ffbe885b799]
/lib/x86_64-linux-gnu/libpthread.so.0(+0x7e9a) [0x7ffbe7ab6e9a]
/lib/x86_64-linux-gnu/libc.so.6(clone+0x6d) [0x7ffbe77e33fd]
Ondrej
Scholar pratham
Ubantu is unsupported OS. I strongly recommend you to use supported OS
-Pratham
Hi there,
I discovered that it was a part of the code which I changed before resulting in that error, however for an unknown reason. I reverted back and the error disappeared. I tried to synthesize the code causing error separately and it went well without any error. Funcitonal simulation was also successful.
Particular, it was a counter with two synchronous reset and self-reset to zero after reaching a fixed value. In the working case, I had one more condition that generated a one-bit signal at certain count. When I moved this condition out of this process to another process, the problem appeared.
2Pratham: Thank you for your answer, I have installed Vivado on Windows 7 also, I prefer working under Linux due to easier SW development for Zynq, embedded Linux compilation, configuration and the whole Linux tool chain. I am aware of the commercial distros that I should be using, hopefully I will manage to get it through in the company.
Many thanks,
Ondrej
Ondrej
