Vivado creates netlist with inputs shorted together
Vivado 2013.4 creates a netlist containing the following nonsense (see the assignments to <const0>) from the attached design.
// Copyright 1986-1999, 2001-2013 Xilinx, Inc. All Rights Reserved.
// Tool Version: Vivado v.2013.4 (lin64) Build 353583 Mon Dec  9 17:26:26 MST 2013
// Date        : Sun Dec 29 22:26:35 2013
// Host        : euklid running 64-bit Ubuntu 12.04.3 LTS
// Command     : write_verilog -force netlist.v
// Design      : issue_010
// Purpose     : This is a Verilog netlist of the current design or from a specific cell of the design. The output is an
//               IEEE 1364-2001 compliant Verilog HDL file that contains netlist information obtained from the input
//               design files.
// Device      : xc7k70tfbg676-3
`timescale 1 ps / 1 ps
(* use_dsp48 = "no" *)
(* STRUCTURAL_NETLIST = "yes" *)
module issue_010
   (a,
    b,
    y);
  input [5:0]a;
  input [3:0]b;
  output [89:0]y;
  wire \<const0> ;
  wire [0:0]\^a ;
  wire xlnx_opt_;
  wire xlnx_opt__1;
  wire [89:0]y;
  assign \<const0>  = a[3];
  assign \<const0>  = a[2];
  assign \<const0>  = a[1];
  assign \<const0>  = b[3];
  assign \<const0>  = b[2];
  assign \<const0>  = b[1];
  assign \<const0>  = b[0];
  assign \^a [0] = a[0];
IBUF IBUF
       (.I(\<const0> ),
        .O(xlnx_opt_));
 This netlist was generated using the following shell command:
/opt/Xilinx/Vivado/2013.4/bin/vivado -mode batch -source script.tcl
I have a couple more Vivado and XST bugs to report. Is this the right place to post them? I also have some ISIM bug reports. Should I post them in the "Simulation and Verification" forum? Or is there a special communications channel for bug reports?
EDIT: Unfortunately I can not attach the files. I always get "The contents of the attachment doesn't match its file type." messages. So here is the content of script.tcl:
read_verilog issue_010.v
synth_design -part xc7k70t -top issue_010
 And here is the content of issue_010.v:
(* use_dsp48="no" *)
module issue_010(a, b, y);
  input [5:0] a;
  input [3:0] b;
  // I have no clue why but Vivado 2013.4 generates a netlist containing:
  //   assign \<const0>  = a[3];
  //   assign \<const0>  = a[2];
  //   assign \<const0>  = a[1];
  //   assign \<const0>  = b[3];
  //   assign \<const0>  = b[2];
  //   assign \<const0>  = b[1];
  //   assign \<const0>  = b[0];
  //   IBUF IBUF
  //         (.I(\<const0> ),
  //          .O(xlnx_opt_));
  wire [80:0] y0;
  wire [4:0] y1;
  wire [3:0] y2;
  output [89:0] y;
  assign y = {y0,y1,y2};
  assign y0  = 0;
  assign y1  = {4{{3{b}}}};
  assign y2  = 4'b1000 * a;
endmodule
FYI
I just confirmed that this bug has been fixed in an internal build of Vivado 2014.3.
This version is scheduled to be released in October.
Best regards
Dries
Give Kudos to a post which you think is helpful and reply oriented by clicking the star next to the post.
Result of 6-bit expression is truncated to fit in 4-bit target.
Result of 48-bit expression is truncated to fit in 5-bit target.
Check these in the code.
Deepika.
Deepika.
Hmm..
I do not get this messages. Are you using a different script or command line? (In know that XST generates such messages, but this is a report about Vivado.) However, this version of the test case should not have the issue and still produces the same flawed output:
  input [5:0] a;
  input [3:0] b;
  wire [80:0] y0;
  wire [4:0] y1;
  wire [3:0] y2;
  wire [47:0] tmp1;
  wire [5:0] tmp2;
  output [89:0] y;
  assign y0  = 0;
  assign tmp1  = {4{{3{b}}}};
  assign tmp2  = 4'b1000 * a;
  assign y1 = tmp1[4:0];
  assign y2 = tmp2[3:0];
endmodule
However, I have to add that also the original version is correct Verilog. Par. 5.6 from The Verilog Standard IEEE Std 1364-2005 clearly states:
If the width of the right-hand expression is larger than the width of the left-hand side in an assignment, the
MSBs of the right-hand expression will always be discarded to match the size of the left-hand side.
Implementations are not required to warn or report any errors related to assignment size mismatch or
truncation. Truncating the sign bit of a signed expression may change the sign of the result.
So I have to strongly object to the notion that above messages are valid reason to generate invalid output.
Also note that I'm not looking for a work around or support in any way. (This test case is very unstable and even small changes will make the behavior go away anyways.) I'm trying to report a bug so Xilinx can improve their product by fixing it in the next version of the software.
Hi Clifford,
first of all, my sincere apologies that so far nobody took the responsibility to investigate and file a CR.
Please do keep your bug reports coming!
We highly appreciate such clear-cut cases with small testcases. That makes filing a CR much easier for us & for development to better understand the issue and resolve it.
I ran an equivalence check against a generated verilog netlist of 2014.1, 2014.2 RC and 2014.3 alpha.
I also checked with use_dsp48 = yes and no.
In all cases the behaviour was the same and the netlist does not match the RTL code. (there was a small difference between yes and no)
I filed CR799205 to get this fixed in our tools. Unfortunately I can't promise that it will make 2014.2 as we are getting relative close to release data. I do hope they can solve it by 2014.3.
Best regards
Dries
FYI
Best regards
Dries
