shaikon
Voyager
Voyager
Vivado optimization report
Is there an auto-generated Vivado report that summarizes logic that has been optimized away (due to being unused, driven by constant values, etc...) ?
hongh
For synthesis, you can check the log file of the synthesis.
For opt_design, you can try -debug_log & -verbose option:
Ex: opt_design -debug_log -verbose
shaikon
Voyager
Voyager
Thanks - but this doesn't answer my question.
"Is there an auto-generated Vivado report that summarizes logic that has been optimized away" ?
hongh
I'm afraid that the answer is "No"
@shaikon
I’m sure you know this, but for the benefit of other readers….
In Vivado and after running synthesis and implementation, you can easily search through Warning, Info, and Status, messages for indications that Vivado has optimized things.
As shown below, first place as checkmark next to Warning, Info, and Status.  Then type a key word (I used “merging”) in the Search: box to get a list of all messages having the key word.  Other key words indicating optimization are “trimmed” and “removed” – and perhaps there are more.
Mark
shaikon
Voyager
Voyager
Sure,
I used this method today...
Other search words I find helpful are:
VCC, GND, constant, unused, optimized.
But this kind of is kind of primitive.
IMO - Vivado removing unused logic is important enough to have a special report dedicated to it.
