delomax
Vivado synthesis doesn't check for width mismatch when assigning an element of an array
Usually when assigning vectors (in VHDL) Vivado will check for width mismatch and give error Synth 8-690 if the widths do not match, such as in this code:
architecture rtl of my_entity is
  signal a : std_logic_vector(31 downto 0);
  signal b : std_logic_vector(7 downto 0);
begin
  a <= b; -- Assigning 32 bit vector to 8 bit vector
end rtl;
However, if the vector being assigned is an element of an array type, this width checking doesn't seem to happen. For example, this code does not cause a synthesis error in Vivado 2018.3:
  type array_t is array (natural range <>) of std_logic_vector(31 downto 0);
  signal a : array_t(3 downto 0); -- Range here is not important...
begin
  a(0) <= b; -- Assigning 32 bit vector to 8 bit vector
end rtl;
Is this a Vivado bug or is there a reason this checking does not occur?
hemangd
Hi @delomax ,
I have filed CR (Change request) on this issue and development may make necessary changes in upcoming Vivado versions.
hemangd
Don't forget to give kudos and mark it as accepted solution if your issue gets resolved.
alvaro.navarro
Hi.
Did this issue get fixed in 2019.1?
I may not be sufficiently familiar with xilinx pages to follow issues, but I see no mention about it in 2018 known issues page, nor can I find a bugfixes list for 2019.
Cheers
hemangd
Hi @alvaro.navarro ,
Development is still working on it and it is not fixed yet.
hemangd
drjohnsmith
dont hold your breath
this is VHDL, and seems fomr experiance that Xilinx have all but droped support for Xilinx.
Seems they only use SytemVerilog and HLS in house,
maps-mpls
Mentor
Mentor
At least he got a response from @hemang .
*** Destination: Rapid design and development cycles *** Unappreciated answers get deleted, unappreciative OPs get put on ignored list ***
alvaro.navarro
Hi, @hemangd
Do you know if it got fixed in 2019.2 or will be fixed in 2020.1?
Álvaro
richardhead
Hi @alvaro.navarro  and @delomax
I tried the OPs code in 2019.2, and at first it appears that there is a fault.
But then I realised that because it has no ports, it actually just removes everything (and hence does no checking)
If you use the following, you get a range check failure in VHDL and VHDL2008 modes:
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity my_entity is
  port (
    ip    : in  std_logic_vector(7 downto 0);
    op    : out std_logic_vector(3 downto 0)
end my_entity;
begin
  b    <= ip;
  op   <= a(0);
end rtl;
So I dont know whether it was really ever an issue, as an enaborated design would also likely be empty.
alvaro.navarro
It wrote the question because a couple of weeks ago it happened to me again, and my design has ports and is not optimized away etc. The good thing is simulation does catch the error and warns about it. If you don't simulate it and directly implement the code, it goes ahead with synthesis and finishes without error. I don't know what logic it actually implements, haven't looked into it.
I'm still in 2018.3, btw.
jsammy
Can someone from Xilinx provide an update on this CR?
Also, can you provide any insight in what logic is implemented in the case of:
begin
end rtl;
i.e. does it zero-extend or sign-extend the source signal?
maps-mpls
Mentor
Mentor
If there is a bug (looks like there might be) synthesize and see. Open synthesized design, then hit the F4 hot key and poke around the generated schematic. You can also first select the module in the netlist before hitting the F4 key to narrow things down a bit.
VHDL is not Verilog.  VHDL is strongly typed.  The width and type in an assignment must match.
If you want to zero extend, you could do this:
a(0) <= X"000000" & b; -- other methods possible
If you want to sign extend, you could try:
a(0)(31 downto 8) <= (others => b(b'high)); -- you'll have to test syntax, should work...I have too many languages in my head at the moment
a(0)(b'range) <= b;  -- should work
I would not rely on the default behavior, especially if there is a bug.
richardhead
@jsammy
Even if this wasnt a bug, it would do neither, as std_logic_vector is not a numeric type.
Go with what @maps-mpls said
jsammy
Perhaps I was unclear.
I was not asking how to zero or sign extend.  My concern is that given the Vivado synthesis bug described in the original post, it clearly will synthesize *something* even with a syntax error in the code.  Imagine a very large design with code that was not all written by you.  It is infeasible to comb through this code to look for the aforementioned bug.  So my question to Xilinx is what exactly is it synthesizing in this case?  This may help direct debugging efforts if we had more knowledge as to what it was actually implementing.
To be clear, this is a critical Vivado synthesis bug that must be fixed.  I am just looking for an update on its progress, and some more background on the behavior of the bug in existing releases.
drjohnsmith
do you not sign extend using the resize function of VHDL ?
http://userweb.eng.gla.ac.uk/scott.roy/DCD3/05_Arithmetic.pdf
alvaro.navarro
To @jsammy : As I mentioned in a previous post, simulation of the design does catch the bug. So if you can, do some simulation. You may not need to do a complete testbench of all the functionality if it's too complicated. I don't remember exactly because it's been a long time, but I think just running the simulation would catch the error during the initial compilation of the files.
To @hemangd or any other Xilinx mod: do we have any news on this severe, 18-month-old bug in Vivado? Seriously, Vivado is (was?) failing to properly detect a syntax error in VHDL, and producing who-knows-what logic instead. It's really dissappointing. We're using Microsemi (Microchip) Polarfire in a different part of the project, and I must say their team has been way more responsive when dealing with problems in Libero that what I have seen in this CR.
About zero/sign-extension: it's not about how to zero-extend or sign-extend. @jsammy was just trying to guess what the Vivado bug does. Anyway, thanks for passing by, and try to help.
Cheers
richardhead
@alvaro.navarro
Unfortunately Xilinx are notoriously unresponsive, particularly when it comes to VHDL bugs. Even when you get notified on the forum a CR is raise, no one gives a ticket number, theres no way to track it, and there are no listed bug fixes in release notes.Any bugs I raise I keep open on the forum and manually check them again on the next release (giving a fix/no fixed in vXXX bump to the post). It is HIGHLY frustrating. It alsoo doesnt help that Xilinx has gone to a 6 monthly release schedule.
If you are some big corp buying a few million dollars of chips every year, you're likely to get better response, and often you can get hotfixes and special versions too.
I suspect with Microsemi having such a smaller market share, it is far more important to them to keep the little guy happy. When I raise a ticket with Aldec, I usually get a response within a day, and I have had a patch sent within 2 days. Its great.
drjohnsmith
Xilinx will probably use this as an example of why HLS is so much better
jsammy
@alvaro.navarro well said
It seems like this post should not be marked as solved by @delomax until the corresponding fixed version of Vivado has been released and verified :shrug:
maps-mpls
Mentor
Mentor
The price of salt is being impacted by this thread.
