Vivado
I created my design in Vivado 2017.4 Version and now I want to transfer it to 2018.3 version, while synthesis I got an error stating " [Synth 8-3493] module does not have matching formal port for component port. "
Could you please tell why does this error come although my design was perfectly working in the 2017.8 version.
Xilinx sometimes change the behavior (and porting) of the IP's.
so when u upgraded the IP's then it might be that there major changes between the IP's and u need to generate them from scratch.
btw, there is a way of using old IP's in new Vivado.
If the module mentioned is not from a Xilinx IP, you need to check if the port mapping in the module instantiation matches the component declaration.
-vivian
如果提供的信息能解决您的问题,请标记为“接受为解决方案”。
如果您认为帖子有帮助,请点击“奖励”。谢谢!
