WARNING: [Synth 8-7025] The ram_style = ultra set on ROM "xpm_memory_base:/mem" can not be honored for this device. This ROM will be implemented using BRAMs
Hi all,
I am trying to use a XPM template for a Dual Port ROM instance, and I am trying to configure the MEMORY_PRIMITIVE set to "ULTRA" instead of "BLOCK".
When I observe the Synthesis Report, I see:
Is it impossible to use the attribute MEMORY_PRIMITIVE = "ultra" ?
In UG974 the information related with the ROM specifies MEMORY_PRIMITIVE can be set to "auto", "block", "distributed" and "ultra" (see allowed values column), but then in the Description column only "auto", "block" and "distributed" are mentioned.
Could somebody clarify if ROMs can use "ULTRA" attribute?
Thanks a lot.
Hi, @sesalido ,
For UltraScale+ and Ultrascale device, UltraRam doesn't support initialization, so the only thing you can get is a blank/empty ROM built out of UltraRam.
So you can only use "distributed" or "block".
Hi @sesalido ,
I guess to the tool is reporting for ROM. For ROM the attribute is rom_style and the accepted value are:
Block and distributed.
Where as in case of RAM we can have ultra too.
Raj
Hi, @sesalido ,
Please confirm whether the device you are using contains Ultra-RAM resource first.
Hi Hongh,
Yes, in fact other components (Single Port RAM or Dual Port RAM) that I specified to use "ultra" were inferred correctly. The problem is with the XPM ROMs.
I think they are restricted to use "distributed" or "block".
What is your opinion about that?
Thanks a lot
Hi Raj,
Thanks for your answer. I was confused about the column "Allowed values" in XPM_MEMORY_DPROM section in UG974, in which "auto", "block", "distributed" and "ultra" were indicated.
But then, it seems the ROMs don't allow you to use "ultra" attribute. Is it correct?
Thanks a lot,
Serafín
Hi, @sesalido ,
Hi Hongh, it is what I supposed, but with your response, I confirm it.
Thanks a lot for your help!
