varenyam
WARNING:Xst:1293 - FF/Latch <n_reg_1> has a constant value of 0 in block <uart_tx_unit>. This FF/Latch will be trimmed during the optimization process.
localparam [1:0]
idle = 2'b00,
start = 2'b01,
data = 2'b10,
stop = 2'b11;
// signal declaration
reg [1:0] state_reg,state_next;
reg [3:0] s_reg,s_next;
reg [2:0] n_reg,n_next;
reg [7:0] b_reg,b_next;
reg tx_reg,tx_next;
always @(posedge clk, posedge reset)
if(reset)
begin
state_reg <= idle;
s_reg <= 0;
n_reg <= 0;
b_reg <= 0;
tx_reg <= 1'b1;
end
else
begin
state_reg <= state_next;
s_reg <= s_next;
n_reg <= n_next;
b_reg <= b_next;
tx_reg <= tx_next;
end
initial
begin
n_reg=3'b000;
n_next=3'b000;
end
always @*
begin
state_next = state_reg;
tx_done_tick = 1'b0;
s_next = s_reg;
n_next = n_reg;
b_next = b_reg;
tx_next = tx_reg;
case(state_reg)
idle:
begin
tx_next = 1'b1;
if(tx_start)
begin
state_next = start;
s_next = 0;
b_next = din;
end
end
start:
begin
tx_next = 1'b0;
if(s_tick)
if(s_reg==15)
begin
state_next = data;
s_next = 0;
n_next = 0;
end
else
s_next = s_reg + 1'b1;
end
data&colon;
begin
tx_next = b_reg[0];
if(s_tick)
if(s_reg==15)
begin
s_next = 0;
b_next = b_reg >> 1 ;
if(n_reg==(DBIT-1))
state_next = stop;
else
n_next = n_reg + 1'b1;
end
else
end
stop:
begin
tx_next = 1'b1;
if(s_tick)
if(s_reg==(SB_TICK-1))
begin
state_next = idle;
tx_done_tick = 1'b1;
end
else
end
endcase
end
//output
assign tx = tx_reg;
endmodule
how can i remove warnings????
vijayak
Please check this AR.
http://www.xilinx.com/support/answers/18397.html
Thanks,Vijay
bassman59
Historian
Historian
Answered here.
itsna
@varenyam, have you solved the problem? I have the exact same problem and I still can't get it to work, the block is removed and many signals are not connected even though I have connected those signals in the code, and when I program the FPGA, the transmitter didn't work
nupurs
@itsna,
Did you try the suggestions provided here: https://forums.xilinx.com/t5/Synthesis/Meaning-of-WARNING-Xst-1898-Due-to-constant-pushing/td-p/336971
Nupur
anusheel
@itsna
You need to check the design connectivity to make sure warnings are valid or not. First step would be to start from the RTL view and then compare the connections in the generated netlist.
However, you can preserve cells and nets whenever required, but I would recommend to first analyze the design instead of using attributes.
Anusheel
Helpful answer -> Give Kudos
