mkoko
WARNING:Xst:1336 - (*) More than 100% of Device resources are used
please
i want to solve this warning in my code :
my code is
module big_reg #(parameter n = 16, parameter num = 120)
input clk,
input rst,
input validin,
input [n-1:0] input_LDPC,
output reg validout,
output reg end_frame,
output [7:0] addreses, //block adress
output reg [num*n-1:0] out_reg
reg [1903:0] mem;//119*16
reg [7:0] i;
reg [6:0] j;
reg flag1;
reg [6:0] w;
assign addreses[7:0] = i[7:0] - 8'b00000001;//subtract 1 as requird to make i in first block =0
always@(posedge clk or negedge rst)
begin
if(!rst)
begin
mem <= 1904'b0;
i <=8'b0;
j <= 8'b0;
flag1 <=1'b0;
end_frame <=1'b0;
validout <=1'b0;
w<=0;
end
else
begin
end_frame<=1'b0;
if (flag1 == 1)
begin
end_frame <= 1;
flag1<=1'b0;
end
else if(validin)
begin
if (i<135)//specify address block number
begin
if(j<119)//block
begin
mem[j*n+:n] <= input_LDPC;
validout <= 0;
j<= j+1;
end
else if (j == 119)
begin
out_reg[1919:1904]<= input_LDPC;//non blocking assigment
out_reg[1903:0]<= mem;
validout <= 1;//block end
i <= i+1;
j <= 0;
end
end
else
begin
if(i == 135 && w<120)//dummy block
begin
out_reg[w*n+:n]<= 0;
w<=w+1;
end
else if(w==120)
begin
validout<=1;
flag1<=1;
j<=0;
i<=0;
w<=0;
end
end
end
end
end
endmodule
Device Utilization Summary (estimated values)
Logic Utilization
Used
Available
Utilization
Number of Slice Registers
3852
42000
9%
Number of Slice LUTs
5820
21000
27%
Number of fully used LUT-FF pairs
3848
5824
66%
Number of bonded IOBs
1949
210
928%!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Number of BUFG/BUFGCTRLs
1
32
3%
umamahe
The following AR http://www.xilinx.com/support/answers/17042.htm may addressed your issue.
vemulad
You need to post this question in synthesis board. I will move this to the correct board.
Which device are your targetting?
The IOB's in the design are greater than the number of IOB's in the device.
Is this used as submodule in the design going further? If yes, you can disable IO buffer insertion in synthesis settings as below.
If this is the top module in your design then you need to reduce the number of IOB's or target a bigger device.
Deepika.
Deepika.
vsrunga
Agree with Deepika and wanted to point one more thing.
Below lines of code are the one that consume more IOBs,  I do not think in hardware there will be any memory with 120 data ports,  if this is for simualtion that's fine else you may need to check if reg(120) is included in the top level intentiaonally and modify your code accordingly.
parameter num = 120
Hope this helps.
Vanitha.
