Visitor contec2
WARNING:Xst:790
	constant FPGA_PINS	:integer:= 385;
type t_pins_type is array (0 to FPGA_PINS-1) of std_logic;
constant pins_type :t_pins_type := (others => '0');
function check_pin(pinnr :std_logic_vector) return integer is variable v_pinnr: integer range 0 to FPGA_PINS-1; begin if unsigned(pinnr) > to_unsigned(FPGA_PINS-1,9) then return 0; -- pin doesn't exist else v_pinnr := conv_integer(pinnr); pins_type(v_pinnr) = '0' then end if; end check_pin;
 When I try to synthesize the above code, ISE gives me this warning:
WARNING:Xst:790 - "C:/syn/test.vhd" line 166: Index value(s) does not match array range, simulation mismatch.
I don't understand why it shows this warning, and most importantly how i can get it away.
Thanks in advance!
