What is the disparity between DIRECT_ENABLE and EXTRACT_ENABLE?
Hi All,
Could anyone explain the disparity between DIRECT_ENABLE and EXTRACT_ENABLE? In my view, they have the similar functionality.
Re: What is the disparity between DIRECT_ENABLE and EXTRACT_ENABLE?
Hi, @araongao2015 ,
These 2 attributes do have the similar functionality.
As I understand:
DIRECT_ENABLE is focusing on the enable signal itself(From driver).
EXTRACT_ENABLE is focusing on the register driven by the enable signal. (From loads )
Hong
Since the question has been posed - has anyone been able to get this property to work?
Normally, I don't really care how synthesis builds logic.  But, under certain circumstances, one wishes to force the tools hand a bit.
I've tried the "direct_enable" property - and found it doesn't work at all.  I used it, as documented to try and force synthesis to use the"CE" pin of a low-level FF.  Every instance I checked however, I found synthesis building the CE via a feedback MUX on the D input.
Or am I misinterpreting what this property is supposed to be doing?
Mark
