ssampath
Voyager
Voyager
What is the main intention of the elaboration design in vivado ?
Hi Friends,
What is the main intention of the Elaboration option in the vivado GUI navigator ?
1) is it only for seeing schematics before mapping ?
What we have to observe in this ? what is the main intention to provide this option ?
NOTE:  Any suggestions or solutions are highly appreciated.
S Sampath
-Sampath
hemangd
Hi @ssampath,
I think this forum post will help you to understand more about elaboration design.
https://forums.xilinx.com/t5/Synthesis/what-exactly-is-elaborating-a-design/td-p/682043
Have a look into it.
hemangd
hemangd
hemangd
Hi @ssampath,
hemangd
hemangd
ssampath
Voyager
Voyager
Thank you
-Sampath
hemangd
Hi @ssampath,
If your question is answered and/or your issue is solved, please mark a response that resolved your issue, as Accepted Solution (more info on this can be found here: https://forums.xilinx.com/t5/help/faqpage/faq-category-id/solutions#solutions). This way, the topic can be completed then.
If this is not solved/answered, please reply in the thread.
Thanks in advance and have a great day.
hemangd
hemangd
