igorkarkanuf
What is the result of to_float in float pakage ?
I created a code in VHDL which uses the floating package. (IEEE_proposed) I'm using the function that converts a floating point constant called to_float in the package. However, I was wondering what is the result of this function. Does it convert floating point to a 32 bit floating point binary or does it convert the number to a fixed point? I have to compare 2 codes in floating point, so I need to be sure that it is a good comparison.
blindobs
If you open Vivado float_pkg/float_generic_pkg you will see that to_float is
  function to_float (
    arg                     : REAL;
    constant exponent_width : NATURAL    := float_exponent_width;  -- length of FP output exponent
    constant fraction_width : NATURAL    := float_fraction_width;  -- length of FP output fraction
    constant round_style    : round_type := float_round_style;  -- rounding option
    constant denormalize    : BOOLEAN    := float_denormalize)  -- Use IEEE extended FP
    return UNRESOLVED_float
where package default values are:
  generic map (
    FLOAT_EXPONENT_WIDTH => 8,    -- float32'high
    FLOAT_FRACTION_WIDTH => 23,   -- -float32'low
    FLOAT_ROUND_STYLE    => ieee.fixed_float_types.ROUND_NEAREST,  -- round nearest algorithm
    FLOAT_DENORMALIZE    => true,  -- Use IEEE extended floating
    FLOAT_CHECK_ERROR    => true,  -- Turn on NAN and overflow processing
    FLOAT_GUARD_BITS     => 3,     -- number of guard bits
    NO_WARNING           => false, -- show warnings
    FIXED_PKG            => ieee.fixed_pkg
blindobs
  function to_float (
    arg                     : REAL;
  generic map (
