What to do if auto_detect_xpm fails?
I'm seeing errors when I run synth_design because it can't find a xpm_fifo_async module.
I'm building with Vivado 2018.3 in non project mode. I issue the auto_detect_xpm command just prior to running synth_design and see this warning:
WARNING: [filemgmt 56-315] Source scanning failed during design analysis. To get more details run synthesis or simulation and check the log.
Then during synthesis I see this error:
ERROR: [Synth 8-439] module 'xpm_fifo_async' not found [/home/integral/private/users/jenkins/workspace/FPGA/src/main/rtl/common/XpmAsyncFifo.v:88]
The module that is failing instantiates a xpm_fifo_async. It seems like auto_detect_xpm isn't working.
Re: What to do if auto_detect_xpm fails?
HI @david.hoffman,
Are you using non-project flow (as you are using auto_detect_xpm)? If yes, did you try to synthesize the file in project mode?
Did you correctly add the library in your source file?
Library xpm;
use xpm.vcomponents.all;
Can you try the following command and see if it makes any difference
set_property XPM_LIBRARIES XPM_FIFO [current_project]
Florent
