subagha
XST 11.2 Takes a lot of memory and never completes the synthesis
 I tried to synthesize a small example using xst 11.2 but the synthesis takes more than 20 GB of memory and never completes,
So I have to kill the tool.
Please find the code Below
library ieee;
    use ieee.std_logic_1164.all;
entity tmp is
    port (
        i1 : in     std_ulogic;
        o1 : out    std_ulogic_vector(31 downto 0)
end tmp;
architecture rtl of tmp is
  signal sig1            : std_ulogic_vector(31 downto  0);
  signal sig2    : std_ulogic_vector(15 downto  0);
begin
     tmp_process: process (sig2, sig1)
       variable var1 : std_ulogic_vector(15 downto 0);
       variable var2   : std_ulogic_vector(1 downto 0);
       variable var3     : std_ulogic_vector(3 downto 0);
     begin
          var3        := (others => '0');
          for i in 15 downto 0 loop
              var2      := sig1((i*2+1) downto (i*2));
              case var2 is
                  when "00" =>
                      var3(0)  := var3(0) or var1(i);
                  when "01" =>
                      var3(1)  := var3(1) or var1(i);
                  when "10" =>
                      var3(2)  := var3(2) or var1(i);
                  when "11" =>
                      var3(3)  := var3(3) or var1(i);
                  when others =>
                      null;
              end case;
         end loop;
     end process;
end rtl ;
Your help is most appreciated.
regards,
subagha
bassman59
Historian
Historian
You are trying to synthesize a huge combinatorial loop.
Don't do that.
eilert
The same thread can be found on comp.arch.fpga
There are already several responses to it.
