XST fatal error during synthesis process
Hi there, I'm facing an error I've never seen before.
I'm using tools in version 13.2 for Virtex-6 FPGAs.
I have a design in ISE whose behavioral simulation works fine. The "Check Syntax" commmand in "Synthesize - XST" process also works (with no warning and no error). Unfortunately, I have an error during synthesis of my design :
"FATAL_ERROR:Xst:xstblock2aig.c:2814:1.13 -   No init on FF ][615   Process will terminate. For technical support on this issue, please open a WebCase with this project attached at http://www.xilinx.com/support."
Any suggestion in mind ?
Pascal.
Finally, I've found the solution by myself ! :smileyhappy:
The solution was to set the "Keep hierarchy" option of the synthesis process to "Yes" or "Soft" : as my design was a kind of template for testing some connections, XST may do some simplifications that make my design fails.
Any moderator/administrator reading this can list this discussion as solved problem, thanks.
Can you find an FF called "][615" in your RTL code? If yes, give an initial value to this FF. If not, I'd suggest you open a webcase for this problem.
Vivian
如果提供的信息能解决您的问题,请标记为“接受为解决方案”。
如果您认为帖子有帮助,请点击“奖励”。谢谢!
