07-26-2011 05:55 PM
I use the following code as a module and I use it in my VHDL top module. But when I try to syntheis this it gave me the following warning.
:Xst:737 - Found 1-bit latch for signal <TBE>. Latches may be generated from incomplete case or if statements. We do not recommend the use of latches in FPGA/CPLD designs, as they may lead to timing problems.
But I can't find any incomplete case or if in my code. In the top module I map the TBE to an Output port. Could any one please help me?
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
-- Uncomment the following lines to use the declarations that are
-- provided for instantiating Xilinx primitive components.
--library UNISIM;
--use UNISIM.VComponents.all;
entity Rs232RefComp is
Port (
TXD : out std_logic := '1';
RXD : in std_logic;
CLK : in std_logic; --Master Clock = 50MHz
DBIN : in std_logic_vector (7 downto 0); --Data Bus in
DBOUT : out std_logic_vector (7 downto 0); --Data Bus out
RDA : inout std_logic; --Read Data Available
TBE : inout std_logic := '1'; --Transfer Bus Empty
RD : in std_logic; --Read Strobe
WR : in std_logic; --Write Strobe
PE : out std_logic; --Parity Error Flag
FE : out std_logic; --Frame Error Flag
OE : out std_logic; --Overwrite Error Flag
RST : in std_logic := '0'); --Master Reset
end Rs232RefComp;
architecture Behavioral of Rs232RefComp is
-- Component Declarations
-- Local Type Declarations
--Receive state machine
type rstate is (
strIdle, --Idle state
strEightDelay, --Delays for 8 clock cycles
strGetData, --Shifts in the 8 data bits, and checks parity
strCheckStop --Sets framing error flag if Stop bit is wrong
type tstate is (
sttIdle, --Idle state
sttTransfer, --Move data into shift register
sttShift --Shift out data
type TBEstate is (
stbeIdle,
stbeSetTBE,
stbeWaitLoad,
stbeWaitWrite
-- Signal Declarations
constant baudDivide : std_logic_vector(7 downto 0) := "00101000";--"10100011"; --Baud Rate dividor, set now for a rate of 9600.
--Found by dividing 50MHz by 9600 and 16.
signal rdReg : std_logic_vector(7 downto 0) := "00000000"; --Receive holding register
signal rdSReg : std_logic_vector(9 downto 0) := "1111111111"; --Receive shift register
signal tfReg : std_logic_vector(7 downto 0); --Transfer holding register
signal tfSReg : std_logic_vector(10 downto 0) := "11111111111"; --Transfer shift register
signal clkDiv : std_logic_vector(8 downto 0) := "000000000"; --used for rClk
signal rClkDiv : std_logic_vector(3 downto 0) := "0000"; --used for tClk
signal ctr : std_logic_vector(3 downto 0) := "0000"; --used for delay times
signal tfCtr : std_logic_vector(3 downto 0) := "0000"; --used to delay in transfer
signal rClk : std_logic := '0'; --Receiving Clock
signal tClk : std_logic; --Transfering Clock
signal dataCtr : std_logic_vector(3 downto 0) := "0000"; --Counts the number of read data bits
signal parError: std_logic; --Parity error bit
signal frameError: std_logic; --Frame error bit
signal CE : std_logic; --Clock enable for the latch
signal ctRst : std_logic := '0';
signal load : std_logic := '0';
signal shift : std_logic := '0';
signal par : std_logic;
signal tClkRST : std_logic := '0';
signal rShift : std_logic := '0';
signal dataRST : std_logic := '0';
signal dataIncr: std_logic := '0';
signal strCur : rstate := strIdle; --Current state in the Receive state machine
signal strNext : rstate; --Next state in the Receive state machine
signal sttCur : tstate := sttIdle; --Current state in the Transfer state machine
signal sttNext : tstate; --Next state in the Transfer staet machine
signal stbeCur : TBEstate := stbeIdle;
signal stbeNext: TBEstate;
-- Module Implementation
begin
frameError <= not rdSReg(9);
parError <= not ( rdSReg(8) xor (((rdSReg(0) xor rdSReg(1)) xor (rdSReg(2) xor rdSReg(3))) xor ((rdSReg(4) xor rdSReg(5)) xor (rdSReg(6) xor rdSReg(7)))) );
DBOUT <= rdReg;
tfReg <= DBIN;
par <= not ( ((tfReg(0) xor tfReg(1)) xor (tfReg(2) xor tfReg(3))) xor ((tfReg(4) xor tfReg(5)) xor (tfReg(6) xor tfReg(7))) );
--Clock Dividing Functions--
process (CLK, clkDiv) --set up clock divide for rClk
begin
if (Clk = '1' and Clk'event) then
if (clkDiv = baudDivide) then
clkDiv <= "000000000";
else
clkDiv <= clkDiv +1;
end if;
end if;
end process;
process (clkDiv, rClk, CLK) --Define rClk
begin
if CLK = '1' and CLK'Event then
if clkDiv = baudDivide then
rClk <= not rClk;
else
rClk <= rClk;
end if;
end if;
end process;
process (rClk) --set up clock divide for tClk
begin
if (rClk = '1' and rClk'event) then
rClkDiv <= rClkDiv +1;
end if;
end process;
tClk <= rClkDiv(3); --define tClk
process (rClk, ctRst) --set up a counter based on rClk
begin
if rClk = '1' and rClk'Event then
if ctRst = '1' then
ctr <= "0000";
else
ctr <= ctr +1;
end if;
end if;
end process;
process (tClk, tClkRST) --set up a counter based on tClk
begin
if (tClk = '1' and tClk'event) then
if tClkRST = '1' then
tfCtr <= "0000";
else
tfCtr <= tfCtr +1;
end if;
end if;
end process;
--This process controls the error flags--
process (rClk, RST, RD, CE)
begin
if RD = '1' or RST = '1' then
FE <= '0';
OE <= '0';
RDA <= '0';
PE <= '0';
elsif rClk = '1' and rClk'event then
if CE = '1' then
FE <= frameError;
OE <= RDA;
RDA <= '1';
PE <= parError;
rdReg(7 downto 0) <= rdSReg (7 downto 0);
end if;
end if;
end process;
--This process controls the receiving shift register--
process (rClk, rShift)
begin
if rShift = '1' then
rdSReg <= (RXD & rdSReg(9 downto 1));
end if;
end if;
end process;
--This process controls the dataCtr to keep track of shifted values--
process (rClk, dataRST)
begin
if dataRST = '1' then
dataCtr <= "0000";
elsif dataIncr = '1' then
dataCtr <= dataCtr +1;
end if;
end if;
end process;
--Receiving State Machine--
process (rClk, RST)
begin
if RST = '1' then
strCur <= strIdle;
else
strCur <= strNext;
end if;
end if;
end process;
--This process generates the sequence of steps needed receive the data
process (strCur, ctr, RXD, dataCtr, rdSReg, rdReg, RDA)
begin
case strCur is
when strIdle =>
dataIncr <= '0';
rShift <= '0';
dataRst <= '0';
CE <= '0';
if RXD = '0' then
ctRst <= '1';
strNext <= strEightDelay;
else
ctRst <= '0';
strNext <= strIdle;
end if;
when strEightDelay =>
dataIncr <= '0';
rShift <= '0';
CE <= '0';
if ctr(2 downto 0) = "111" then
ctRst <= '1';
dataRST <= '1';
strNext <= strGetData;
else
ctRst <= '0';
dataRST <= '0';
end if;
when strGetData =>
CE <= '0';
dataRst <= '0';
if ctr(3 downto 0) = "1111" then
ctRst <= '1';
dataIncr <= '1';
rShift <= '1';
else
ctRst <= '0';
dataIncr <= '0';
rShift <= '0';
end if;
if dataCtr = "1010" then
strNext <= strCheckStop;
else
end if;
when strCheckStop =>
dataIncr <= '0';
rShift <= '0';
dataRst <= '0';
ctRst <= '0';
CE <= '1';
strNext <= strIdle;
end case;
end process;
--TBE State Machine--
process (CLK, RST)
begin
if RST = '1' then
stbeCur <= stbeIdle;
else
stbeCur <= stbeNext;
end if;
end if;
end process;
--This process gererates the sequence of events needed to control the TBE flag--
process (stbeCur, CLK, WR, DBIN, load)
begin
case stbeCur is
when stbeIdle =>
TBE <= '1';
if WR = '1' then
stbeNext <= stbeSetTBE;
else
stbeNext <= stbeIdle;
end if;
when stbeSetTBE =>
TBE <= '0';
if load = '1' then
stbeNext <= stbeWaitLoad;
else
end if;
when stbeWaitLoad =>
if load = '0' then
stbeNext <= stbeWaitWrite;
else
end if;
when stbeWaitWrite =>
if WR = '0' then
else
end if;
when others =>
end case;
end process;
--This process loads and shifts out the transfer shift register--
process (load, shift, tClk, tfSReg)
begin
TXD <= tfsReg(0);
if tClk = '1' and tClk'Event then
if load = '1' then
tfSReg (10 downto 0) <= ('1' & par & tfReg(7 downto 0) &'0');
end if;
if shift = '1' then
tfSReg (10 downto 0) <= ('1' & tfSReg(10 downto 1));
end if;
end if;
end process;
-- Transfer State Machine--
process (tClk, RST)
begin
if (tClk = '1' and tClk'Event) then
if RST = '1' then
sttCur <= sttIdle;
else
sttCur <= sttNext;
end if;
end if;
end process;
-- This process generates the sequence of steps needed transfer the data--
process (sttCur, tfCtr, tfReg, TBE, tclk)
begin
case sttCur is
when sttIdle =>
tClkRST <= '0';
shift <= '0';
load <= '0';
if TBE = '1' then
sttNext <= sttIdle;
else
sttNext <= sttTransfer;
end if;
when sttTransfer =>
shift <= '0';
load <= '1';
tClkRST <= '1';
sttNext <= sttShift;
when sttShift =>
shift <= '1';
load <= '0';
tClkRST <= '0';
if tfCtr = "1100" then
sttNext <= sttIdle;
else
end if;
when others =>
sttNext <= sttIdle;
end case;
end process;
end Behavioral;
07-26-2011 11:13 PM - edited 07-27-2011 12:13 AM
there is no "when others => " statement for the "case strCur "
And if you dont have any statement to assign here then you can just assgin "null "
which is as follows
when others => null;
Hope this helps.
- Krishna
which is as follows
Hope this helps.
- Krishna
07-27-2011 03:33 AM
07-27-2011 08:57 AM
Your problem is Yet Another Example of Two-Process State Machine FAIL.
Also, all of your synchronous processes have crufty signals on their sensitivity lists.
07-28-2011 02:43 AM
Sensitive list for synchronous processes is process (CLK,asynch_RESET) that's all. Remove all other signals
as told before, assign a value for all signal in your case statements.
lamonnis
07-28-2011 05:13 PM - edited 07-28-2011 05:15 PM
Thank you all for help full replys.
This is niether a project nor home work. I'm trying to learn by my self.
