XST latch error
I use the following code as a module and I use it in my VHDL top module. But when I try to syntheis this it gave me the following warning.
:Xst:737 - Found 1-bit latch for signal <TBE>. Latches may be generated from incomplete case or if statements. We do not recommend the use of latches in FPGA/CPLD designs, as they may lead to timing problems.
But I can't find any incomplete case or if in my code. In the top module I map the TBE to an Output port. Could any one please help me?
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
--  Uncomment the following lines to use the declarations that are
--  provided for instantiating Xilinx primitive components.
--library UNISIM;
--use UNISIM.VComponents.all;
entity Rs232RefComp is
    Port (
        TXD     : out std_logic      := '1';
        RXD     : in  std_logic;
        CLK     : in  std_logic;                                --Master Clock = 50MHz
        DBIN     : in  std_logic_vector (7 downto 0);    --Data Bus in
        DBOUT : out std_logic_vector (7 downto 0);    --Data Bus out
        RDA    : inout std_logic;                        --Read Data Available
        TBE    : inout std_logic     := '1';            --Transfer Bus Empty
        RD        : in  std_logic;                    --Read Strobe
        WR        : in  std_logic;                    --Write Strobe
        PE        : out std_logic;                    --Parity Error Flag
        FE        : out std_logic;                    --Frame Error Flag
        OE        : out std_logic;                    --Overwrite Error Flag
        RST        : in  std_logic    := '0');    --Master Reset
end Rs232RefComp;
architecture Behavioral of Rs232RefComp is
-- Component Declarations
--  Local Type Declarations
    --Receive state machine
    type rstate is (
        strIdle,            --Idle state
        strEightDelay,    --Delays for 8 clock cycles
        strGetData,        --Shifts in the 8 data bits, and checks parity
        strCheckStop        --Sets framing error flag if Stop bit is wrong
    type tstate is (
        sttIdle,            --Idle state
        sttTransfer,    --Move data into shift register
        sttShift            --Shift out data
    type TBEstate is (
        stbeIdle,
        stbeSetTBE,
        stbeWaitLoad,
        stbeWaitWrite
-- Signal Declarations
    constant baudDivide : std_logic_vector(7 downto 0) := "00101000";--"10100011";     --Baud Rate dividor, set now for a rate of 9600.
        --Found by dividing 50MHz by 9600 and 16.
    signal rdReg    :  std_logic_vector(7 downto 0) := "00000000";            --Receive holding register
    signal rdSReg    :  std_logic_vector(9 downto 0) := "1111111111";        --Receive shift register
    signal tfReg    :  std_logic_vector(7 downto 0);                                --Transfer holding register
    signal tfSReg  :  std_logic_vector(10 downto 0)     := "11111111111";    --Transfer shift register
    signal clkDiv    :  std_logic_vector(8 downto 0)    := "000000000";        --used for rClk
    signal rClkDiv :  std_logic_vector(3 downto 0)    := "0000";                --used for tClk
    signal ctr    :  std_logic_vector(3 downto 0)    := "0000";                    --used for delay times
    signal tfCtr    :  std_logic_vector(3 downto 0)    := "0000";                --used to delay in transfer
    signal rClk    :  std_logic := '0';                            --Receiving Clock
    signal tClk    :  std_logic;                                    --Transfering Clock
    signal dataCtr :  std_logic_vector(3 downto 0)    := "0000";        --Counts the number of read data bits
    signal parError:  std_logic;                                    --Parity error bit
    signal frameError: std_logic;                                    --Frame error bit
    signal CE        :  std_logic;                                    --Clock enable for the latch
    signal ctRst    :  std_logic := '0';
    signal load    :  std_logic := '0';
    signal shift    :  std_logic := '0';
    signal par    :  std_logic;
   signal tClkRST    :  std_logic := '0';
    signal rShift    :  std_logic := '0';
    signal dataRST :  std_logic := '0';
    signal dataIncr:  std_logic := '0';
    signal strCur    :  rstate    := strIdle;                 --Current state in the Receive state machine
    signal strNext    :  rstate;                                    --Next state in the Receive state machine
    signal sttCur  :  tstate := sttIdle;                    --Current state in the Transfer state machine
    signal sttNext :  tstate;                                    --Next state in the Transfer staet machine
    signal stbeCur :  TBEstate := stbeIdle;
    signal stbeNext:  TBEstate;
-- Module Implementation
begin
    frameError <= not rdSReg(9);
    parError <= not ( rdSReg(8) xor (((rdSReg(0) xor rdSReg(1)) xor (rdSReg(2) xor rdSReg(3))) xor ((rdSReg(4) xor rdSReg(5)) xor (rdSReg(6) xor rdSReg(7)))) );
    DBOUT <= rdReg;
    tfReg <= DBIN;
    par <=  not ( ((tfReg(0) xor tfReg(1)) xor (tfReg(2) xor tfReg(3))) xor ((tfReg(4) xor tfReg(5)) xor (tfReg(6) xor tfReg(7))) );
--Clock Dividing Functions--
    process (CLK, clkDiv)                                --set up clock divide for rClk
        begin
            if (Clk = '1' and Clk'event) then
                if (clkDiv = baudDivide) then
                    clkDiv <= "000000000";
                else
                    clkDiv <= clkDiv +1;
                end if;
            end if;
        end process;
    process (clkDiv, rClk, CLK)                         --Define rClk
    begin
        if CLK = '1' and CLK'Event then
            if clkDiv = baudDivide then
                rClk <= not rClk;
            else
                rClk <= rClk;
            end if;
        end if;
    end process;
    process (rClk)                                           --set up clock divide for tClk
        begin
            if (rClk = '1' and rClk'event) then
                rClkDiv <= rClkDiv +1;
            end if;
        end process;
    tClk <= rClkDiv(3);                                    --define tClk
    process (rClk, ctRst)                               --set up a counter based on rClk
        begin
            if rClk = '1' and rClk'Event then
                if ctRst = '1' then
                    ctr <= "0000";
                else
                    ctr <= ctr +1;
                end if;
            end if;
        end process;
    process (tClk, tClkRST)                                 --set up a counter based on tClk
        begin
            if (tClk = '1' and tClk'event) then
                if tClkRST = '1' then
                    tfCtr <= "0000";
                else
                    tfCtr <= tfCtr +1;
                end if;
            end if;
        end process;
     --This process controls the error flags--
    process (rClk, RST, RD, CE)
        begin
            if RD = '1' or RST = '1' then
                FE <= '0';
                OE <= '0';
                RDA <= '0';
                PE <= '0';
            elsif rClk = '1' and rClk'event then
                if CE = '1' then
                    FE <= frameError;
                    OE <= RDA;
                    RDA <= '1';
                    PE <= parError;
                    rdReg(7 downto 0) <= rdSReg (7 downto 0);
                end if;
            end if;
        end process;
    --This process controls the receiving shift register--
    process (rClk, rShift)
        begin
                if rShift = '1' then
                    rdSReg <= (RXD & rdSReg(9 downto 1));
                end if;
            end if;
        end process;
    --This process controls the dataCtr to keep track of shifted values--
     process (rClk, dataRST)
        begin
                if dataRST = '1' then
                    dataCtr <= "0000";
                elsif dataIncr = '1' then
                    dataCtr <= dataCtr +1;
                end if;
            end if;
        end process;
      --Receiving State Machine--
    process (rClk, RST)
        begin
                if RST = '1' then
                    strCur <= strIdle;
                else
                    strCur <= strNext;
                end if;
            end if;
        end process;
    --This process generates the sequence of steps needed receive the data
    process (strCur, ctr, RXD, dataCtr, rdSReg, rdReg, RDA)
        begin
            case strCur is
                when strIdle =>
                    dataIncr <= '0';
                    rShift <= '0';
                    dataRst <= '0';
                    CE <= '0';
                    if RXD = '0' then
                        ctRst <= '1';
                        strNext <= strEightDelay;
                    else
                        ctRst <= '0';
                        strNext <= strIdle;
                    end if;
                when strEightDelay =>
                    dataIncr <= '0';
                    rShift <= '0';
                    CE <= '0';
                    if ctr(2 downto 0) = "111" then
                        ctRst <= '1';
                            dataRST <= '1';
                        strNext <= strGetData;
                    else
                        ctRst <= '0';
                        dataRST <= '0';
                    end if;
                when strGetData =>
                    CE <= '0';
                    dataRst <= '0';
                    if ctr(3 downto 0) = "1111" then
                        ctRst <= '1';
                        dataIncr <= '1';
                        rShift <= '1';
                    else
                        ctRst <= '0';
                        dataIncr <= '0';
                        rShift <= '0';
                    end if;
                    if dataCtr = "1010" then
                        strNext <= strCheckStop;
                    else
                    end if;
                when strCheckStop =>
                    dataIncr <= '0';
                    rShift <= '0';
                    dataRst <= '0';
                    ctRst <= '0';
                    CE <= '1';
                    strNext <= strIdle;
            end case;
        end process;
    --TBE State Machine--
    process (CLK, RST)
        begin
                if RST = '1' then
                    stbeCur <= stbeIdle;
                else
                    stbeCur <= stbeNext;
                end if;
            end if;
        end process;
    --This process gererates the sequence of events needed to control the TBE flag--
    process (stbeCur, CLK, WR, DBIN, load)
        begin
            case stbeCur is
                when stbeIdle =>
                    TBE <= '1';
                    if WR = '1' then
                        stbeNext <= stbeSetTBE;
                    else
                        stbeNext <= stbeIdle;
                    end if;
                when stbeSetTBE =>
                    TBE <= '0';
                    if load = '1' then
                        stbeNext <= stbeWaitLoad;
                    else
                    end if;
                when stbeWaitLoad =>
                    if load = '0' then
                        stbeNext <= stbeWaitWrite;
                    else
                    end if;
                when stbeWaitWrite =>
                    if WR = '0' then
                    else
                    end if;
                when others =>
                end case;
            end process;
    --This process loads and shifts out the transfer shift register--
    process (load, shift, tClk, tfSReg)
        begin
            TXD <= tfsReg(0);
            if tClk = '1' and tClk'Event then
                if load = '1' then
                    tfSReg (10 downto 0) <= ('1' & par & tfReg(7 downto 0) &'0');
                end if;
                if shift = '1' then
                    tfSReg (10 downto 0) <= ('1' & tfSReg(10 downto 1));
                end if;
            end if;
        end process;
    --  Transfer State Machine--
    process (tClk, RST)
        begin
            if (tClk = '1' and tClk'Event) then
                if RST = '1' then
                    sttCur <= sttIdle;
                else
                    sttCur <= sttNext;
                end if;
            end if;
        end process;
    --  This process generates the sequence of steps needed transfer the data--
    process (sttCur, tfCtr, tfReg, TBE, tclk)
        begin
            case sttCur is
                when sttIdle =>
                    tClkRST <= '0';
                    shift <= '0';
                    load <= '0';
                    if TBE = '1' then
                        sttNext <= sttIdle;
                    else
                        sttNext <= sttTransfer;
                    end if;
                when sttTransfer =>
                    shift <= '0';
                    load <= '1';
                    tClkRST <= '1';
                    sttNext <= sttShift;
                when sttShift =>
                    shift <= '1';
                    load <= '0';
                    tClkRST <= '0';
                    if tfCtr = "1100" then
                        sttNext <= sttIdle;
                    else
                    end if;
                when others =>
                    sttNext <= sttIdle;
            end case;
        end process;
end Behavioral;
there is no "when others => " statement  for the "case strCur "
And if you dont have any statement to assign here then you can just assgin "null "
which is as follows
when others => null;
Hope this helps.
- Krishna
which is as follows
Hope this helps.
- Krishna
Or it may be because 'TBE' is assigned from only 2 values of the case statement.
BTW, please name your processes. Un-named processes are an Abomination Unto Nuggan.
Historian
Historian
Your problem is Yet Another Example of Two-Process State Machine FAIL.
Also, all of your synchronous processes have crufty signals on their sensitivity lists.
Sensitive list for synchronous processes is process (CLK,asynch_RESET) that's all. Remove all other signals
as told before, assign a value for all signal in your case statements.
lamonnis
Thank you all for help full replys.
This is niether a project nor home work. I'm trying to learn by my self.
