dayana42200
Xst:1710 - FF/Latch <pe_block[0].pe.pe0/Algorithm/Iyij/LeftComp/SCORE_Left_D_0> (without init value) has a constant value of 0 in block <SystolicArray>. This FF/Latch will be trimmed during the optimi
Hi everyone.
I need helps
I get the warning shown in the title during synthesized my top module.
I sub module related to the warning is ok.
I search lots of solution related to the warning. However, I cant see where is the problem.
My simulation is not as I expected since the sub module has been trimmed off.
Thank you in advance
dayana42200
the other coding
dayana42200
allthe source file is attached
