Xst:737 and PhysDesignRules:372 warnings
This is my Verilog code for a programmable sequence detector. The code functions as expected in simulation, but gives me warnings when synthesizing and loading on to the FPGA:
module seq_det(
	input wire clk,
	input wire wreset,
	input wire wA,
	input wire wB,
	input wire wC,
	input wire Program,
	output reg LED
debouncer a_debounce(
    .clk(clk),
    .async_input(wA),
    .synchronized_debounced_pulse(A)
debouncer b_debounce(
    .clk(clk),
    .async_input(wB),
    .synchronized_debounced_pulse(B)
debouncer c_debounce(
    .clk(clk),
    .async_input(wC),
    .synchronized_debounced_pulse(C)
debouncer reset_debounce(
    .clk(clk),
    .async_input(wreset),
    .synchronized_debounced_pulse(reset)
parameter S_IDLE = 0; //idle state
parameter S_PROG = 1; //programming state
parameter S_SEQ_STORE = 2; //storing sequence state
parameter S_DETECT =4; //detect matching sequence state
reg [2:0] next_state, state;
//sequential logic
always @ ( posedge clk )
	begin
	if ( reset )
		state <= S_IDLE;
	else
		state <= next_state;
	end
wire buttonpress;
wire [1:0]letter; //encodes A, B, or C as 2-bits
reg [1:0]seq[0:7]; //stored sequence in 8 x 2-bit register
reg [3:0]seq_len = 3'b0; //stored sequence length
reg [3:0]det_len = 3'b0; //detected sequence length
//2-bit values are assigned to A, B, and C
assign buttonpress = A | B | C;
assign letter = A ? 2'b00 : B ? 2'b01 : C ? 2'b10 : 2'b11;
//combinational logic
always @ ( seq[0], seq[1], seq[2], seq[3], seq[4], seq[5], seq[6], seq[7], state, Program, reset, buttonpress, seq_len, det_len, letter )
	begin
		next_state = S_IDLE;
		case( state )
			S_IDLE: 	begin //IDLE STATE
						if ( Program )
								begin
								LED = 0;
								next_state = S_PROG; //programming mode enabled
								end
						else if ( reset )
								begin
								LED = 0;
								next_state = S_IDLE; //idle state, detected sequence length reset
								det_len = 3'b0;
								end
						else if ( buttonpress )
								begin
								next_state = S_DETECT; //button pressed, check for matching sequence
								end
						else
								next_state = S_IDLE; //else, idle state
						end
			S_PROG: 	begin //PROGRAMMING STATE
						seq_len = 3'b0; //lengths of stored and detected sequence cleared
						det_len = 3'b0;
						next_state = S_SEQ_STORE; //next state stores user-input sequence
						LED = 0;
						end
	 S_SEQ_STORE:	begin //STORING SEQUENCE STATE
						if ( buttonpress )
								begin
								seq[seq_len] = letter; //store button pressed
								seq_len = seq_len + 1; //increment stored sequence counter
								next_state = S_SEQ_STORE; //next state waits for button release;
								end
						else if ( !Program )
								next_state = S_IDLE; //program button de-asserted, next state idle
						else
								next_state = S_SEQ_STORE; //programming mode still enabled, continue storing sequence
						end
		S_DETECT: 	begin //DETECT MATCHING SEQUENCE STATE
						if ( buttonpress && ( letter == seq[det_len] ) ) //if button pressed and matches current stored 2-bit sequence value
								begin
								if ( det_len + 1 == seq_len ) //if length of current detection equals the length of the stored
										LED = 1; //match detected, LED on
								else
									begin
										det_len = det_len + 1; //else, increment detection length counter
										next_state = S_DETECT; //wait for button release
									end
								end
						else if ( buttonpress && ( letter != seq[det_len]) ) //if button pressed and does not match current stored 2-bit sequence value
								begin
								det_len = 3'b0; //no match, reset detection
								LED = 0;
								end
						else
						end
		  default:	begin
						LED = 0;
						end
		endcase
  end
endmodule
Warnings:
WARNING:Xst:737 - Found 2-bit latch for signal <seq_0>. Latches may be generated from incomplete case or if statements. We do not recommend the use of latches in FPGA/CPLD designs, as they may lead to timing problems.
WARNING:Xst:737 - Found 2-bit latch for signal <seq_1>. Latches may be generated from incomplete case or if statements. We do not recommend the use of latches in FPGA/CPLD designs, as they may lead to timing problems.
WARNING:Xst:737 - Found 2-bit latch for signal <seq_2>. Latches may be generated from incomplete case or if statements. We do not recommend the use of latches in FPGA/CPLD designs, as they may lead to timing problems.
WARNING:Xst:737 - Found 2-bit latch for signal <seq_3>. Latches may be generated from incomplete case or if statements. We do not recommend the use of latches in FPGA/CPLD designs, as they may lead to timing problems.
WARNING:Xst:737 - Found 2-bit latch for signal <seq_4>. Latches may be generated from incomplete case or if statements. We do not recommend the use of latches in FPGA/CPLD designs, as they may lead to timing problems.
WARNING:Xst:737 - Found 2-bit latch for signal <seq_5>. Latches may be generated from incomplete case or if statements. We do not recommend the use of latches in FPGA/CPLD designs, as they may lead to timing problems.
WARNING:Xst:737 - Found 2-bit latch for signal <seq_6>. Latches may be generated from incomplete case or if statements. We do not recommend the use of latches in FPGA/CPLD designs, as they may lead to timing problems.
WARNING:Xst:737 - Found 2-bit latch for signal <seq_7>. Latches may be generated from incomplete case or if statements. We do not recommend the use of latches in FPGA/CPLD designs, as they may lead to timing problems.
WARNING:Xst:737 - Found 1-bit latch for signal <LED>. Latches may be generated from incomplete case or if statements. We do not recommend the use of latches in FPGA/CPLD designs, as they may lead to timing problems.
WARNING:Xst:737 - Found 4-bit latch for signal <det_len>. Latches may be generated from incomplete case or if statements. We do not recommend the use of latches in FPGA/CPLD designs, as they may lead to timing problems.
WARNING:Xst:737 - Found 4-bit latch for signal <seq_len>. Latches may be generated from incomplete case or if statements. We do not recommend the use of latches in FPGA/CPLD designs, as they may lead to timing problems.
WARNING:Security:42 - Your software subscription period has lapsed. Your current
WARNING:PhysDesignRules:372 - Gated clock. Clock net seq_len_not0001 is sourced
   by a combinatorial pin. This is not good design practice. Use the CE pin to
   control the loading of data into the flip-flop.
WARNING:PhysDesignRules:372 - Gated clock. Clock net seq_0_not0001 is sourced by
WARNING:PhysDesignRules:372 - Gated clock. Clock net seq_1_cmp_eq0000 is sourced
WARNING:PhysDesignRules:372 - Gated clock. Clock net seq_2_cmp_eq0000 is sourced
WARNING:PhysDesignRules:372 - Gated clock. Clock net seq_3_cmp_eq0000 is sourced
WARNING:PhysDesignRules:372 - Gated clock. Clock net seq_4_cmp_eq0000 is sourced
WARNING:PhysDesignRules:372 - Gated clock. Clock net seq_5_cmp_eq0000 is sourced
WARNING:PhysDesignRules:372 - Gated clock. Clock net seq_6_cmp_eq0000 is sourced
WARNING:PhysDesignRules:372 - Gated clock. Clock net seq_7_cmp_eq0000 is sourced
WARNING:PhysDesignRules:372 - Gated clock. Clock net det_len_not0001 is sourced
WARNING:PhysDesignRules:372 - Gated clock. Clock net LED_not0001 is sourced by a
WARNING:Security:42 - Your software subscription period has lapsed. Your current version of Xilinx tools will continue
Phase 12  : 0 unrouted; (Par is working to improve performance)WARNING:Route:455 - CLK Net:seq_len_not0001 may have excessive skew because
WARNING:Route:455 - CLK Net:det_len_not0001 may have excessive skew because
I've been working on this for weeks and can't find a solid solution to removing these warnings. Any help would be greatly appreciated. Thanks
Re: Xst:737 and PhysDesignRules:372 warnings
besides the latches, coming from incomplete ifs and cases in the combinatorical part of your design, the tool sees a lot of signals used as clocks for some reason.
Since these clocks are derived from internal logic they are using generic routing ressources, which causes problems due to heavy delays and skew. This must not happen unintended!
See the ISE language templates or search the web for proper verilog FSM coding techniques to identify the mistakes in your code.
btw.
A lot of code, no matter how badly written, works nice in simulation.
But just because in simulation most anything is allowed that can be expressed by the used language.
This is no guarantee that you will be able to synthesize this code at all. Or even if synthesizable that the code really behaves the same, e.g. due to stuff that is simply ignored by synthesis etc. .
Have a nice synthesis
  Eilert
Instructor
Instructor
Here is an example of what Eilert is describing, from your posted code:
  case( state )
   S_IDLE:
    begin //IDLE STATE
     // LED = ??;      // default assignment for LED variable is missing
     // det_len = ??;  // default assignment for det_len variable is missing
     if ( Program )
       begin
        LED = 0;
       end
     else
      if ( reset )
       begin
        LED = 0;
        det_len = 3'b0;
       end
      else  // no assignment for LED or det_len here
       if ( buttonpress )
        begin
        end
       else
     end
You have not defined assignments for LED or det_len for all possible conditions, so the synthesiser has no choice but to infer a latch -- a storage element -- to maintain unchanged values for these variables.  The variables tested for conditional assignment will become the latch enables -- the clocks -- for these storage elements.
As an aside:  Thank you for well-formatted code in your posting.  It helps greatly that your code is presented in a readable form.
-- Bob Elkind
SIGNATURE:
Summary:
Guide
Guide
You need to take a step back and think hardware.
For everything in this code you have to think about exactly what you expect in terms of hardware for what you are writing. You have done this for your actual state machine bits (state), which are implemented as flip-flops. But what about everything else?
Of particular concern are the seq, seq_len, and det_len... What are these?
In your "next state" calculation you have things coded as
  seq_len = seq_len+1
  det_len = det_len+1
What are these supposed to be in hardware? Are they flip-flops? No - they are not updated only on the positive edge of the clock, they are updated under certain conditions in your next_state calculation (which is combinatorial logic). But yet, you expect them to hold state. So what are they? The answer is "unintentional latches".
Next, the "seq". What is this? It has eight 2 bit entries. But what are they? Again, you expect them to hold state, but what are they?
   - are they to be implemented in a block RAM? No. A block RAM has a clocked read and a clocked write. You are updating their value combinatorially
  - are they to be implemented in a distributed RAM? No. A distributed RAM has a clocked write, but can use an asynchronous (or combinatorial) read
  - are they to be implemented in 16 flip-flops? No. Again, they are updated in combinatorial process.
So what are they? Again, the answer is "latches".
So your code is fundamentally flawed. You haven't actually figured out how you are going to manage seq_len, dec_len and seq as hardware constructs. You have basically coded them as if you were coding in C...
You need to architect this design, and then write RTL that matches the architecture you have in mind.
(And, as bassman will say) - the two process state machine is always error prone. I acknowledge that there are sometimes reasons to use the two process state machine, but it is really the exception, rather than the rule. The original dogma for using the two process state machine comes from a limitiation in Synopsys Design Compiler prior to something like version 3.1 - that reason hasn't existed since the early 90's (more than 20 years ago!). Its time that universities stop teaching the two process state machine, and teach the one process state machine as the "norm", and advocate using the 2 process one only when there are specific reasons for doing so.
Avrum
