Teacher muzaffer
accessing systemverilog interface parameters
I have an interface definition like this:
interface foo #(BAR=50) (input clk, rst);
endinterface
Later this interface gets passed to a module and the interface parameter is used in a signal definition.
foo f1(.clk(), .rst());
module baz(foo f1);
logic [f1.BAR:0] b1;
When I try to synthesize this I get an error which says "constant expression cannot contain a hierarchical identifier". I have seen some discussion about this on the SV-BC list but I am not sure what they have concluded. Any ideas how to implement something like this ?
Re: accessing systemverilog interface parameters
@muzaffer@jmartel
I checked a small test case with 2016.2 and its working at my end. Can you check and confirm?
Anusheel
Helpful answer -> Give Kudos
Try doing as mentioned in the below example.
interface Channel #(parameter N = 0)
(input bit Clock, bit Ack, bit Sig);
bit Buff[N-1:0];
initial
for (int i = 0; i < N; i++)
Buff[i] = 0;
always @ (posedge Clock)
if(Ack = 1)
Sig = Buff[N-1];
else
Sig = 0;
endinterface
// Using the interface
module Top;
bit Clock, Ack, Sig;
// Instance the interface. The parameter N is set to 7using named
// connection while the ports are connected using implicit connection
Channel #(.N(7)) TheCh (.*);
TX TheTx (.Ch(TheCh));
endmodule
Thanks,Vijay
Teacher muzaffer
unfortunately this doesn't help me. What I am trying to do is to figure out what N is with in the module TX in your example. ie:
module TX(channel Ch);
logic [Ch.N:0] foo;
endmodule
Vivado thinks this is a hierarchical access but it really is not. The interesting part is that axi.aclk type hierarchical references work (supposing an interface instance named axi with a port called aclk) but axi.WIDTH does not work (where WIDTH is a parameter) with an error saying hierarchical access is not supported. I think it's a bug in Vivado synthesis.
Can you give me the testcase to check at my end?
Thanks,Vijay
Teacher muzaffer
top.sv:
interface test_if #(WIDTH = 32) (input aclk, aresetn); logic [WIDTH:0] wide; endinterface module top( input reset, input sys_clk); test_if test_if(.aclk(sys_clk), .aresetn(reset)); always @(posedge test_if.aclk) begin:test reg [test_if.WIDTH:0] testvec; testvec <= 0; end endmodule
 Try the above top.sv with the following script & command line "vivado -mode tcl -source test.tcl
test.tcl:
create_project -in_memory -part xc7k325tffg900-2
set_property target_language Verilog [current_project]
set_property board xilinx.com:kintex7:kc705:1.1 [current_project]
read_verilog -sv {
  top.sv
synth_design -top top -part xc7k325tffg900-2
I have filed a CR#770501 for this issue. I will keep you posted on the developments.
Thanks,Vijay
Visitor akash_0406
Is this fixed in 2014.1?
I see the same problem with structures as well.
Visitor chiggs_pv
Any update on this?
I'm also encountering the same issue.
Accessing systemverilog interface parameters is not supported currently.
Achutha
Teacher muzaffer
does this mean this issue won't be fixed for 2014.3 either?
Scholar markcurry
Another way of trying to do this, which should work, but still doesn't (taking your example):
top.sv:
function integer get_width();
  get_width = WIDTH;
endfunction
endinterface
 input        sys_clk);
	reg [test_if.get_width():0] testvec;
	testvec <= 0;
end
endmodule
I change what looked like a hier. ref for the tool into a Constant function (albeit a function defined within the interface). Constant functions have been supported for a while, so I thought this might do the trick.
This doesn't work with Vivado either, and it should.
Vijay - Can you add this variant to the testcase?
Mark
Observer glester
Has anyone found an answer to this?
I'm having the same problem with 2014.4
ERROR: "[Synth 8-660] unable to resolve '<function name>'"
I've tried the interface with and without modports, and with and without the full import function prototype in the modport.  I've tried the function both as a constant and non-constant, as automatic and not.  The error is unassailable.
Gerry
Teacher muzaffer
Another way to do something similar is to use $bits. If you are trying to find the size of an object/type it should (does) work. I am doing this right now:
module foo  #(type IT = complex, type OT=complex) (
input rst,
input clk,
input IT in,
output OT out
logic signed [$bits(in.i)-1:0] fooi, fooq;
where complex is a struct which has i & q elements of parameterized size.
Visitor jmartel
Does anybody have something new on this topic?
I'm currently working with Vivado 2016.1 and still having the same issue...
Teacher muzaffer
@vijayak any update on this issue? What happened with CR#770501 ?
@muzaffer@jmartel
Anusheel
Visitor jmartel
I tested back my use case with 2016.2 and it doesn't seem to work either.
Could you please send me your "small test case" example so I can compare if it matches my code requirements?
Joe
Teacher muzaffer
my test program which I posted 2 years ago now synthesizes with 2016.2. Kudos Xilinx.
Observer h4cks4w
I can confirm the results @muzaffer saw.  However, if you pass the interface to another module, things break down again.
I've modified test test.  top2.sv demonstrates the issue:
interface test_if #(WIDTH = 0) (input aclk, aresetn);
modport mp (
input aclk,
input aresetn,
input wide
endinterface
`define USE_MODPORT
`ifdef USE_MODPORT
module foo ( test_if.mp the_if );
`else
module foo ( test_if the_if );
`endif
localparam WIDTH = the_if.WIDTH;
//localparam WIDTH = 32;
always @(posedge the_if.aclk) begin:test
        reg [WIDTH:0] testvec;
        testvec <= 0;
end
endmodule
 input        sys_clk);
test_if #(.WIDTH (32)) test_if(.aclk(sys_clk), .aresetn(reset));
foo
foo
( .the_if (test_if) );
endmodule
And test2.tcl will drive it:
create_project -in_memory -part xcvu095-ffvb2104-2-e
read_verilog -sv {
  top2.sv
synth_design -top top -part xcvu095-ffvb2104-2-e
quit
Using this command:
$ vivado -mode tcl -source test2.tcl
I get the following error:
INFO: [Synth 8-638] synthesizing module 'foo' [/srv/home/tstrader/workspace/vivado_intf_params/top2.sv:13]
ERROR: [Synth 8-27] scoped/hierarchical type name not supported [/srv/home/tstrader/workspace/vivado_intf_params/top2.sv:13]
ERROR: [Synth 8-285] failed synthesizing module 'foo' [/srv/home/tstrader/workspace/vivado_intf_params/top2.sv:13]
ERROR: [Synth 8-285] failed synthesizing module 'top' [/srv/home/tstrader/workspace/vivado_intf_params/top2.sv:26]
Which is pointing at foo's port map, but I think it's actually angry about "localparam WIDTH = the_if.WIDTH;".  You can see this by swapping that line with the hard-coded, commented-out line below it.  Also, the error message is different if you don't use a modport'ed interface (but I suspect it's actually the same problem):
INFO: [Synth 8-638] synthesizing module 'foo' [/srv/home/tstrader/workspace/vivado_intf_params/top2.sv:15]
ERROR: [Synth 8-3892] undeclared type 'test_if'  [/srv/home/tstrader/workspace/vivado_intf_params/top2.sv:15]
ERROR: [Synth 8-285] failed synthesizing module 'foo' [/srv/home/tstrader/workspace/vivado_intf_params/top2.sv:15]
You can comment out "`define USE_MODPORT" to see this behavior.
This is all with Vivado 2017.1.
@h4cks4w
Apparently this is known not to work :(
https://www.xilinx.com/support/answers/55135.html
Hopefully a future version will fix this.
I think that Vivado is making a distinction between assigning to a localparam vs a parameter. In Vivado 2018.3, this code fails synthesis inconsistently
module my_module(
    intf.in my_intf
parameter BUS_WIDTH = my_intf.BUS_WIDTH;
endmodule
while this code seems to work
module my_module(
    intf.in my_intf
localparam BUS_WIDTH = my_intf.BUS_WIDTH;
endmodule
Using parameter allows other modules to perform a hierarchical access themselves and Vivado is possibly blowing up trying to interpret that, but localparam restricts access of the variable to the module itself. This fixed it for me at least!
-David
