witte
arrays of sfixed: xst ignores signedness and generates incorrect logic
Dear Community,
in a VHDL design I'm using the sfixed (signed fixed point) data type from the floatfixlib (part of VHDL 2008 standard and part of the ieee_proposed library delivered with ISE). In order to have a nice and proper coding style and to enable a parametrizable design, I'm using arrays of sfixed. In RTL simulation verification is passed perfectly, however, when mapping the design onto an FPGA board (V2P100) for prototyping, the behavior is wrong. After tidious sessions with logic-analyzers, post-place&route and post-synthesis simulation, I've been able to narrow the issues down to a set of testcass which seem to indicate that XST is interpreting the elements of an array of sfixed as unsigned values in "some" cases. Unfortunately, I could not find any hint on this issue in the internet/xilinx forums and ARs.
I hope, the information provided here is suitable to reproduce the problem on other systems. It would be really great if someone could provide a solution/workaround to get a correct synthesis result for V2P100 devices and ISE <= 10.1sp3 (unfortunately we are limited to this device/tools combination) without modifying existing code too much.
All necessary information/source code can be found below and in the attached zip archive. If there is any question left open, please do not hesitate to concat me.
With best regards and thanks in advance,
    Martin Witte
Summary:
   Under many circumstances, Xilinx XST seems to handle signed sfixed
   array signals as unsigned values. This is a serious problem with
   comparisons and bitwidth increasing multiplications/additions/...
   XST seems to generate incorrect logic, making FPGA prototype
   implementations fail badly which are using the floatfixlib library
   as part of the VHDL 2008 standard.
Files provided:
   * fixedpt_test.vhd            : entity with test cases
   * pack.vhd                    : package with type definitions and constants
   * fixedpt_test_synthesis.vhd  : example synthesis result
                                   (post-synthesis simulation model)
                                   for a V2P100 device, ISE 10.1 SP3
Test Case Project Setup
   To synthesize this test case, you need the following steps:
   * Create a new ISE project for your favourite FPGA type and
     add the files "fixedpt_test.vhd" and "pack.vhd" to the
     project (library "work")
   * Create a library called "ieee_proposed" and add the file
     <path-to-ise>/vhdl/src/ieee_proposed/fixed_pkg_c.vhd
   Default settings should be fine for the project. I tried to
   switch off / change various synthesis settings without any
   difference in the synthesis result.
Tested Tools/Versions/Settings
   * ISE  9.2 SP4, Linux, 32 bit, Virtex 2 Pro 100
   * ISE 10.1 SP3, Linux, 64 bit, Virtex 2 Pro 100
   * ISE 11.1      Linux, 64 bit, Virtex4 SX35
   * floatfixlib provided by Xilinx
     (<path-to-ise>/vhdl/src/ieee_proposed/fixed_pkg_c.vhd)
   * floatfixlib provided by David Bishop
How to check for (in)correctness?
   * Run the synthesis
   * Generate a post-synthesis simulation model. You'll find the
     generated file under
     <ise-project-dir>/netgen/synthesis/fixedpt_test_synthesis.vhd
   * Instead spending effort to set up a simulation project, I
     recommend to have a look into the file "fixedpt_test_synthesis.vhd".
     You can already observe the issues by watching out for hard wired
     inputs for the output buffer cells of the cmp_res signals (would not
     be hard wired if synthesized correctly). Furthermore, depending on
     the FPGA architecture, you can easily detect the wrong wiring of the
     MSBs of the multiplieres synthesized incorrectly (hard wired to Gnd
     instead of sign extended) - particularly easy for V2P devices.
Test Cases:
* Comparisons x < 0
  Of course, for this particular sign check, we could simply use the MSB.
  However, these test cases are used to have an easy verification
  flow to analyze the general problem XST has with the signedness of
  sfixed array elements. If synthesized correctly, the outputs of the
  cmp_res signals are not constant, otherwise they are typically wired to
  '1'/VCC. This can easily be observed without simulation by just looking
  at the post-synthesis VHDL model (see above).
  The following tests have been implemented:
  cmp_res( 4) passed: non-array sfixed port
  cmp_res( 5) passed: SIGNED array element
  cmp_res( 0) FAILED: sfixed array element
  cmp_res( 1) FAILED: sfixed array element with explicite type cast
                      to sfixed by function call
  cmp_res( 9) FAILED: sfixed array element with explicite type cast
                      to sfixed by inlined conversions
                      BUT: onyl fails if (see cmp_res(15))
                           "recast_sig2 <= fsfixed(test_sfixed_array(1))"
  cmp_res( 9) passed: sfixed array element with explicite type cast
                      BUT: onyl passed if (see cmp_res(15))
                           "recast_sig2 <= test_sfixed_array(1)"
  cmp_res( 3) passed: sfixed array element with explicite type cast
                      to sfixed (temporary signal) by function call
  cmp_res(15) passed: sfixed array element assignment to sfixed
                      temporary signal
                      BUT: This line influences cmp_res(14)!!!
                      (for details, please look at the comments in the
                       code)
  cmp_res( 6) FAILED: sfixed array element with assignment to sfixed
                      temporary variable (in process)
  cmp_res(14) passed: sfixed array element with explicite type cast
                      to sfixed variable by function call (in process)
  cmp_res(14) FAILED: sfixed array element with explicite type cast
  cmp_res( 2) FAILED: sfixed array element (port array copied to
                      local array)
  cmp_res( 7) passed: sfixed array element assigned to shared sfixed
                      variable
  cmp_res( 8) FAILED: sfixed array assigned to shared sfixed
                      array variable
  cmp_res(10) passed: neg. sfixed constant array element
  cmp_res(11) passed: pos. sfixed constant array element
  cmp_res(12) FAILED: local sfixed array element (result of addition)
                      The adder inputs are non-array std_logic_vector
                      ports casted to sfixed
  cmp_res(13) FAILED: local sfixed array element (result of subtraction)
* Multiplication tests
  mul_res1 FAILED:    plain multiplication of sfixed(6 downto -6) array
                      elements. The wiring of the 18x18multiplier has
                      top 6 MSBs set to '0' which results in an unsigned
                      multiplication.
                      Bonus Package: ISE 10.1sp3 synthesis fails with
                      internal error if array elements 2 and 3 are
                      multiplied:
                      "Xst:1709 - Edge <l_ext_index0000>, from block <fixedpt_test>, has no source"
  mul_res2 passed:    multiplication of local sfixed signal with sfixed
                      array port element. Uses only MSBs of 18x18mul
                      without the need for explicit sign extension.
  mul_res3 (FAILED/passed):  Multiplication with helper-workaround-function
                      The sfixed array elements are manually sign-extended
                      to the result bitwidth. Therefore, the numerical
                      result is correct though if it is still handled as
                      unsigned multiplication: The operands are aligned
                      with the LSBs of the 18x18mul inputs and explicitly
                      sign extended.
witte
Hi all,
no solution yet, but at least the urgency solving this specific XST problem has been relaxed - we are in the lucky situation to have also lics for Synplify which synthesizes correct logic. Since this switch to the Synplicity tool flow, our prototype is up and running perfectly now.
Anyway, I believe, that the issue posted here is still worth being investigated in order to improve XST.
   Martin
