ssampath
Voyager
Voyager
bram implementing with FF's instead of BRAM primitives in vivado 2017 ?
HI Friends,
I used  *.v file and *blk_mem*8_2*.v in the file list. what i observed is "Tool is implementing BRAM with FF's and in this case most of times tool is exiting without any error", but i replace these *.v with *.xci then there is no issue ?
Can you please suggest why its happening ?
-Sampath
-Sampath
ssampath
Voyager
Voyager
HI ,
if i replce the *.v file with *xci, tool mapping corretly to BRAMs.
-Sampath
-Sampath
hongh
Hi, @ssampath ,
If you intend to apply the source code of IP to replace XCI file, please confirm you have add all the source code files into the correct library.
To get all the files needed for synthesis, you can use the below command:
%report_compile_order -of [get_ips XX]
ssampath
Voyager
Voyager
HI ,
-Sampath
-Sampath
