tifmdgo01
can results change if I synthesize again?
hi.
I experienced a different operation when I re synthesised without changing programs and synthesis option.
Previously well-behaved programs did not work after re-synthesis.
I want to make a custom ip so that it does not have to be rewritten each time.
However, this problem reduces reliability.
In what situations can this be happening?
syedz
@tifmdgo01,
The results should not change if the source and project properties are not altered.
You can compare the log file to know which stage in synthesis is changing. Also check the following AR
https://www.xilinx.com/support/answers/61599.html
--Syed
syedz
@tifmdgo01,
--Syed
syedz
@tifmdgo01,
Did the above shared information helped in narrowing down the issue?
--Syed
tifmdgo01
thank you for your answer.
I understood information in your link.
The content of the link mostly coincides with my environment.
I will apply the recommendations soon.
