rigoni
change debug output format during synthesis
Hi all,
 I would like to change the format output during synthesis of my rtl to make an external IDE able to manage the vivado error and follow corresponding lines numbers.
I looked at the function defined in ::common called set_msg_config but it aims only at changing the behavior of the message not the display output.
I also tried to override the function send_msg_id without any success, when in synthesis it simply displays the usual messages ignoring my new function. here is my dummy test:
namespace eval ::common {
proc send_msg_id { args } {
 puts "TEST"
namespace export send_msg_id
thanks in advance
rigoni
Thanks for the reply Pratham, good to know .. I'll do with a regexp then, and I'll convert this post to a hint for the next version :-)
Andrea
pratham
You cannot modify.
-Pratham
rigoni
Andrea
