Observer ma8d9
Hi ,
I'm new brand in fpga I wrote a code for my project but actually when I synthax it software take a lot of problem on me is there any body to help me and check it?
Re: check
Hi @ma8d9 ,
1. Are you facing errors in synthesis phase?
2. Provide the snapshot of the errors which you are facing.
hemangd
Re: check
Hi @ma8d9:
Which tool are you using? Vivado or ISE? I am not sure what are the problems exactly which are being generated by software (and which one, Vivado or ISE) you are talking about?
If you are using Vivado, you can go through some tutorials provided by Xilinx to help yourself to understand the basics.
Here is the list of tutorial for beginers for getting started.
1.https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_3/ug910-vivado-getting-started.pdf
2.https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_3/ug892-vivado-design-flows-overview.pdf
     -This user guide provides an overview of working with the Vivado Design Suite to create a
       new design for programming into a Xilinx device.
3.https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_3/ug895-vivado-system-level-design-entry.pdf
    -This  user guide will help you to design from full register-transfer level (RTL) creation to bitstream generation.
You can refer following video tutorial to understand the messaged being generated by software.
https://www.xilinx.com/video/hardware/understanding-vivado-messages.html
Priyanka
If you find this information useful, please mark it "accept as solution"
Observer ma8d9
Re: check
Thanx for your time, I'm using ISE .
May I send to you my codes ?
Re: check
Hi @ma8d9 :
Yes, you can attach the file here.
Priyanka
Observer ma8d9
Re: check
Re: check
Hi @ma8d9 :
Which version of ISE are you using? What is the device?
ISE supports Spartan-6, Virtex-6  devices families and their previous generations. Xilinx recommends Vivado for new design starts with Virtex-7, Kintex-7, Artix-7, and Zynq-7000.
Kindly go through ISE Design Suite Release Notes of respective version to check architecture support for commercial products in the ISE design
Suite WebPACK tool. (For ISE 14.7 : https://www.xilinx.com/support/documentation/sw_manuals/xilinx14_7/irn.pdf )
You can go through ISE In-Depth Tutorial to understand how this tool works.
https://www.xilinx.com/support/documentation/sw_manuals/xilinx14_7/ise_tutorial_ug695.pdf
Please share the synthesis report generated by ISE. This will get clarity on what errors you are getting.
Priyanka
Re: check
Hi @ma8d9 ,
hemangd
Scholar richardhead
Re: check
@ma8d9
The errors in your code are mostly missing or extra ; or ,
In a port declaration, the last port should have no ;
entity blah is
  port (
    port1  : std_logic; --note ;
    port2 : std_logic   -- NOTE: no ;
end entity;
similarly when doing a port map, the last entry should have no ,
inst : some_comp
port map (
  port1 => port1,  -- NOTE comma ,
  port2 => port2  -- NOTE no comma
Other things.
1. There is no such library as ieee.signed_std
2. sha 256 vhdl com2 has two lines at the top that should be commented.
3. Integer literals are 123 not '123'
Basically, ISE will tell you all of this. These are basic syntax errors, you should try and fix them yourself (there are a lot of them).
