Advisor
Advisor
dashed lines vs full lines in synthesized schematic
I'm wondering why some lines are 'dashed' when opening a synthesized schematic, for example :
Re: dashed lines vs full lines in synthesized schematic
@ronnywebers
The dashed lines(nets) are also driving some other logic which are not shown now.
Double-click on the dashed lines and the complete connection will be shown.
Nupur
@ronnywebers
Nupur
