golson
defining a input signal as a clock signal
I have a signal that is created from the XORing of two signals,  Data Strobe decoding for the clock.  Then I take that signal
and run it into a BUFG.   This signal is fed into a Hierachical Block where the input name of the block is different than
the clock signal coming out of the BUFG.
I am looking in the Constraints editor for the signal name so I can constain the clock period of the derived clock signal but I can not find it in the list of clocks in the constraint editor.
Is there a attribute I can put in VHDL modules that will define the derived signal as a clock.
Thank You
austin
g,
If the signal drives the clock pins of DFF in IOB or CLB, then it is a clock (it is implicit in what it gets wired to).
I would look in FPGA_Editor, and find the name of the clock net, as you will need a PERIOD constraint on this clock to allow the tools to know what to do about the timing.
Austin Lesea
Principal Engineer
Xilinx San Jose
austin
g,
http://www.xilinx.com/support/documentation/sw_manuals/xilinx11/ug612.pdf
page 35, 47 ...
Austin Lesea
Principal Engineer
Xilinx San Jose
golson
Thank You Austin,
  I looked at the RTL Schematic and I can see the name of the signal there.  I will try to constrain the signal (clk)
and see if it works.  The title of the message should have said defining a internal signal as a clock signal.
Thank You,
  Gary
golson
I tried using my net name in my case, GLOBAL_CAM_DS_CLK.
It could not find the signal eventhough I saw this name in the FPGA Editor.
So I tried using the Timing Analyzer and created a Report on Clock Regions  in the report it showed the following
 CAM_IF_TP/CAM_INPUT_PATH1/CAM_ACCPT/mux_cam_clkf
     CAM_IF_TP/CAM_INPUT_PATH1/GLOBAL_CAM_DS_CLK
Now I tried to use these statements:
NET "CAM_IF_TP/CAM_INPUT_PATH1/GLOBAL_CAM_DS_CLK" TNM_NET = CAM_IF_TP/CAM_INPUT_PATH1/GLOBAL_CAM_DS_CLK;
TIMESPEC TS_GLOBAL_CAM_DS_CLK = PERIOD "GLOBAL_CAM_DS_CLK" 20 ns HIGH 50%;
To me it looks like internally generated clocks use a more complicated name.  If I used just the
name GLOBAL_CAM_DS_CLK it will not find the Net.
It is now appearing on the synthesis report as CAM_IF_TP/CAM_INPUT_PATH1/GLOBAL_CAM_DS_CLK
Thanks Again
