different synthesis strategies without IP's
I need different synthesis strategies for my design on an XC7S6. I have to translate 2 components by “Default” to place them exactly for a critical timing. The rest has to be translated with "AreaOptimized_high" so that everything fits into the chip. What is the best way to do this? I tried to use the components as IP, but the placement is not done according to my constraint.
Re: different synthesis strategies without IP's
Hi @mauell ,
As per your requirment you can try BLOCK_SYNTH property.
For more information on that, check the below UG:
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2019_1/ug901-vivado-synthesis.pdf
Raj
Hi @mauell ,
Raj
Thank you so much, that's how it worked!
Previously I had only tried to put the "BLOCK_SYNTH" property in the vhdl source, which was ignored.
