divider operator an synthesis
hi to all,
i know that
XST supports Dividers only if:
• The divisor is constant and a power of 2.
• The description is implemented as a shifter.
• Both operands are constant.
XST exits with a specific error message in all other cases
But i notice that new versions os ISE sysnthesize the / operator with signed and unsigned data. i try to describe a simple divider in VHDL and synthesize and i notice that it pass all the implementation flow.
Is it normal?
Re: divider operator an synthesis
It might have inferred divider IP/DSP48 blocks, check your synthesis report.
Not sue why do you think it is not normal.
Vanitha.
