bbinb
does ram_style attribute has no effect in Vivado 2020.1
I try to infer block RAM by using Xilinx VHDL language templates. I use ram_style attribute as follows:
type t_my_ram is array (0 to 134) of std_logic_vector (7 downto 0);
signal my_ram : t_my_ram := ( 0 => x"AA", 1 => x"BB", 5 => x"CC", 9 => x"DD", others => (others => '0'));
attribute ram_style : string;
attribute ram_style of my_ram : signal is "block";
begin
process (clk) begin
if (rising_edge(clk)) then
   if (ram_we = '1') then
      my_ram(ram_addr) <= ram_di;
   end if;
end if;
end process;
ram_do <= my_ram(ram_addr);
But after I synthesized the RTL, I get LUT utilization used as memory, instead of Block RAM in the synthesis report.
After all, I dont want Vivado to choose RAM type, why ram_style attribute does not work? Do I miss sth?
bbinb
!!! Beginner mistake !!!
I had just re-used another file content and the process block which infers directly distributed RAM as the RAM output assignment is not in a clocked process, which causes the distributed RAM content.
sorry the RAM output assignment should be in a clocked process content as:
process (clk) begin
   end if;
end if;
end process;
richardhead
You don't show the whole code,  but the reason is likely because the address is not registered.  Only lutram can do asynchronous read.
bbinb
process (clk) begin
   end if;
end if;
end process;
bbinb
I think my problem is about this RAM issues, like for most people usually the same case as I search through the web: "NOT USING LANGUAGE TEMPLATE OF XILINX PROPERLY".
Just now I saw a post of  "anusheel" in another thread:
To infer a BRAM, logic should have:
  1. Registered outputs
  2. All Output Registers have the same control signals.
  3. Design should have synchronous reset
Anusheel
So my problem was also not using registered output.
