editing rtl schematic
i'm trying to synthesis a structural vhdl code, and my question is, if there is any posibility to edit the rtl schematic. Also i want to save it and convert it into structural code?
You cannot edit the RTL Schematic.
You can use Netgen to generate post-synthesis (gate-level) simulation model file. Not sure if this is the structural code you want. Refer to "Command Line tools User Guide" for information of Netgen.
Vivian
如果提供的信息能解决您的问题,请标记为“接受为解决方案”。
如果您认为帖子有帮助,请点击“奖励”。谢谢!
ok, thanks, but verilog source can be converted ratter in a schematic source type?
Historian
Historian
My parser blew up on this.
