Advisor ronnywebers
Advisor
error in synthesised schematic of inferred SRL16E ?
I used the shift register example code from UG901
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
--use IEEE.NUMERIC_STD.ALL;
entity singlebit_delay is
generic (
    DEPTH       : integer := 10
port (
    reset                       : in std_logic;
    clock                       : in std_logic;
    din                         : in  std_logic;
    dout                        : out std_logic
end singlebit_delay;
architecture Behavioral of singlebit_delay is
	signal shift_reg : std_logic_vector(DEPTH-1 downto 0);
begin
	process(clock)
	begin
		if rising_edge(clock) then
			shift_reg <= shift_reg(DEPTH-2 downto 0) & din;
		end if;
	end process;
    dout <= shift_reg(DEPTH-1);
end Behavioral;
instantiation is as follows :
    singlebit_delay_i : singlebit_delay
    generic map( DEPTH => 9 )
    port map( reset => reset, clock => clock, din => s_ms_frame_detect, dout => ms_frame_complete);
now simulation after synthesis is ok, but I'm puzzled by the synthesised schematic :
according to UG953, depth of the SRL16E primitive is :
(8 x A3) + (4 x A2) + (2 x A1) + A0 + 1
(8 x   0) + (4 x    0) + (2 x   1) +  0  +  1 =  3
adding to that the extra FF that seems to be inferred all times as the final bit of a shift register, I see only 4 flip-flops of delay?
note that post-synthesis simulation shows 9 clock cycles delay, which is expected. Is this a bug in the schematic representation of the SRL16E primitive?
Advisor ronnywebers
Advisor
Re: error in synthesised schematic of inferred SRL16E ?
I also want to note some strange inference results, I tried out to change the generic 'DEPTH' parameter from 2 to 8, and checked each time the synthesised schematic. That gave me the following results :
DEPTH = 2 (does not infer SRL16E)
DEPTH = 3 (from here on infers SRL16E)
DEPTH = 4
DEPTH = 5
DEPTH = 6
DEPTH = 7
DEPTH = 8
DEPTH = 9
So a few things that I noticed :
1) from DEPTH >= 3, an SRL16E is inferred, which sounds logical to me
2) after the SRL16E, there is always at least 1 FF : Question : is this to improve timing?
3) for DEPTH = 6, and DEPTH = 7, additional FF's are inferred, instead of putting the delay steps into the SRL16E -> why is this?
4) for DEPTH = 8 and DEPTH = 9, the A values look incorrect, and that keeps on going for larger values of DEPTH, see my original question, this looks like an error to me (?)
