fixed_pkg and VHDL 2008
I'm trying to compile the VHDL code below. I set Vivado to use VHDL 2008. The synthesis failed in some cases but I definetely do not see the reason.
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
use ieee.fixed_pkg.all;
entity pouet is
port (
    -- Main signals
    CLK    : in std_logic;
    RESETN    : in std_logic;
    -- Data out
    dout    : out std_logic_vector(7 downto 0)
end pouet;
architecture Behavioral of pouet is
constant coeff_8b : ufixed(4 downto -3) := "10101010";
-- OPTION A1
constant coeff : ufixed(7 downto -6) := to_ufixed (0.29, 7, -6);
-- OPTION A2
--constant coeff : ufixed(7 downto -6) := "00000000010011";
begin
	process(CLK)
	begin
        if (rising_edge (CLK)) then
            if(RESETN = '0') then -- synchronous reset
                dout <= (others => '0');
            else
                  -- OPTION B1
                 dout <= to_slv(resize(coeff,7,0));
                  -- OPTION B2
                  --dout <= to_slv(coeff_8b);
            end if;
        end if;
	  end process;
end Behavioral;
When I try to synthesize with option A1, I get the following error:
[Synth 8-421] mismatched array sizes in rhs and lhs of assignment
Everything runs smoothly with option A2... but I do not understand why the first option does not work.
If I now try to synthesize with option A2 (which works) and option B1, I get the error:
[Synth 8-690] width mismatch in assignment; target has 8 bits, source has 31 bits
Where does the "31 bits" come from?
If i synthesize with option B2 only, it seems to work.
Thank you in advance,
Alexis
I had the same problem, I checked into the fixed_pkg file and I didn't find any problem...
In order to solve the issue I use this method:
signal ufixed_size : ufixed(7 downto -6);
constant coeff : ufixed(7 downto -6) := to_ufixed (0.29, ufixed_size);
