fixed_point libary error
hi guys,
well i am using fixed_point_pkg from ieee_proposed libary in my project ISE 13.3 for virtex 4 ,it is simulating  with modelsim 6.3 f version when i compiled the library and package but while synthesizing it gives me error as follows
XST :2754  "C:xxx/ieee_proposed/fixed_pkg" line 1019 :alias of function is not supported "
i tried  by changing V-4 to Virtex-6 and changed xst command with "-use new parser yes"  by reffering to other anser posts ,it synthesized, but there was no device utilization and i got error while mapping the project that "design is empty"
please help me out guys thanks in advance.
Re: fixed_point libary error
As the error says, the alias is not supported in old parser. It is supported in new parser, hence it passes synthesis when you use that switch.
But looks like the design getting trimmed completely during map.
Can you open synthesized design and check if the logic is inferred properly? You may run post-translate simulation to check if you are seeing expected results or not.
Attach the synthesis and map report files here (.syr,.map) if possible.
Deepika.
Deepika.
i am attaching the synthesis report and map report
The logic is getting trimmed in synthesis. This is because of logic undriven or driven by constraints.
Below are the warnings from the synthesis report. Please fix this in your code.
* Low Level Synthesis *
WARNING:Xst:1710 - FF/Latch <sig_p_0> (without init value) has a constant value of 0 in block <pwm_gen>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <sig_p_1> (without init value) has a constant value of 1 in block <pwm_gen>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <sig_p_2> (without init value) has a constant value of 0 in block <pwm_gen>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <sig_p_3> (without init value) has a constant value of 1 in block <pwm_gen>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <sig_p_4> (without init value) has a constant value of 1 in block <pwm_gen>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <sig_p_5> (without init value) has a constant value of 1 in block <pwm_gen>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <sig_p_6> (without init value) has a constant value of 1 in block <pwm_gen>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <sig_p_7> (without init value) has a constant value of 1 in block <pwm_gen>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <sig_p_8> (without init value) has a constant value of 0 in block <pwm_gen>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <sig_p_9> (without init value) has a constant value of 0 in block <pwm_gen>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <sig_p_10> (without init value) has a constant value of 0 in block <pwm_gen>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <sig_p_11> (without init value) has a constant value of 0 in block <pwm_gen>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <sig_p_12> (without init value) has a constant value of 0 in block <pwm_gen>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1710 - FF/Latch <sum_-4> (without init value) has a constant value of 1 in block <load_sim>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <sum_-3> (without init value) has a constant value of 1 in block <load_sim>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <sum_-2> (without init value) has a constant value of 0 in block <load_sim>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <sum_-1> (without init value) has a constant value of 0 in block <load_sim>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <sum_0> (without init value) has a constant value of 0 in block <load_sim>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <sum_1> (without init value) has a constant value of 1 in block <load_sim>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <sum_2> (without init value) has a constant value of 0 in block <load_sim>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <sum_3> (without init value) has a constant value of 0 in block <load_sim>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <sum_4> (without init value) has a constant value of 0 in block <load_sim>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <sum_5> (without init value) has a constant value of 0 in block <load_sim>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <sum_6> (without init value) has a constant value of 1 in block <load_sim>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1710 - FF/Latch <pwm_input_0> (without init value) has a constant value of 1 in block <PWM_ERRORSIG>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <pwm_input_1> (without init value) has a constant value of 1 in block <PWM_ERRORSIG>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <pwm_input_2> (without init value) has a constant value of 0 in block <PWM_ERRORSIG>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <pwm_input_3> (without init value) has a constant value of 0 in block <PWM_ERRORSIG>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <pwm_input_4> (without init value) has a constant value of 1 in block <PWM_ERRORSIG>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <pwm_input_5> (without init value) has a constant value of 1 in block <PWM_ERRORSIG>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:2973 - All outputs of instance <Inst_PWM_GEN> of block <pwm_gen> are unconnected in block <DOD_MAIN>. Underlying logic will be removed.
WARNING:Xst:2973 - All outputs of instance <Inst_load_sim> of block <load_sim> are unconnected in block <DOD_MAIN>. Underlying logic will be removed.
WARNING:Xst:2677 - Node <Inst_Clock_divider/clk_out> of sequential type is unconnected in block <DOD_MAIN>.
Analyzing FSM <MFsm> for best encoding.
Optimizing FSM <FSM_0> on signal <curr_state[1:4]> with gray encoding.
State | Encoding
state0 | 0000
state1 | 0001
state2 | 0011
state3 | 0010
state4 | 0110
state5 | 0111
state6 | 0101
state7 | 0100
state8 | 1100
WARNING:Xst:1426 - The value init of the FF/Latch half_duty_5 hinder the constant cleaning in the block pwm_gen.
You should achieve better results by setting this init to 1.
WARNING:Xst:1426 - The value init of the FF/Latch half_duty_4 hinder the constant cleaning in the block pwm_gen.
WARNING:Xst:1426 - The value init of the FF/Latch half_duty_0 hinder the constant cleaning in the block pwm_gen.
WARNING:Xst:1293 - FF/Latch <half_duty_1> has a constant value of 0 in block <pwm_gen>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1896 - Due to other FF/Latch trimming, FF/Latch <half_duty_2> has a constant value of 0 in block <pwm_gen>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1896 - Due to other FF/Latch trimming, FF/Latch <half_duty_3> has a constant value of 0 in block <pwm_gen>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1896 - Due to other FF/Latch trimming, FF/Latch <half_duty_6> has a constant value of 0 in block <pwm_gen>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1896 - Due to other FF/Latch trimming, FF/Latch <half_duty_7> has a constant value of 0 in block <pwm_gen>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <sig_1> (without init value) has a constant value of 0 in block <pwm_gen>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <sig_2> (without init value) has a constant value of 0 in block <pwm_gen>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <sig_3> (without init value) has a constant value of 0 in block <pwm_gen>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <sig_6> (without init value) has a constant value of 0 in block <pwm_gen>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <sig_7> (without init value) has a constant value of 0 in block <pwm_gen>. This FF/Latch will be trimmed during the optimization process.
INFO:Xst:2261 - The FF/Latch <half_duty_0> in Unit <pwm_gen> is equivalent to the following 2 FFs/Latches, which will be removed : <half_duty_4> <half_duty_5>
INFO:Xst:2261 - The FF/Latch <sig_0> in Unit <pwm_gen> is equivalent to the following 2 FFs/Latches, which will be removed : <sig_4> <sig_5>
WARNING:Xst:1710 - FF/Latch <div_11> (without init value) has a constant value of 0 in block <load_sim>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <div_10> (without init value) has a constant value of 0 in block <load_sim>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <div_9> (without init value) has a constant value of 0 in block <load_sim>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <div_8> (without init value) has a constant value of 0 in block <load_sim>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <div_7> (without init value) has a constant value of 0 in block <load_sim>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <div_6> (without init value) has a constant value of 0 in block <load_sim>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <div_5> (without init value) has a constant value of 0 in block <load_sim>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <div_4> (without init value) has a constant value of 0 in block <load_sim>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <div_3> (without init value) has a constant value of 0 in block <load_sim>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <div_2> (without init value) has a constant value of 0 in block <load_sim>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <div_1> (without init value) has a constant value of 0 in block <load_sim>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <div_0> (without init value) has a constant value of 0 in block <load_sim>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <div_-1> (without init value) has a constant value of 0 in block <load_sim>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <div_-2> (without init value) has a constant value of 1 in block <load_sim>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <div_-3> (without init value) has a constant value of 1 in block <load_sim>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <div_-4> (without init value) has a constant value of 0 in block <load_sim>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <div_-5> (without init value) has a constant value of 1 in block <load_sim>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <div_-6> (without init value) has a constant value of 1 in block <load_sim>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <div_-7> (without init value) has a constant value of 0 in block <load_sim>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <div_-8> (without init value) has a constant value of 0 in block <load_sim>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <div_-9> (without init value) has a constant value of 0 in block <load_sim>. This FF/Latch will be trimmed during the optimization process.
Deepika.
ok but the code is simulating properly in modelsim 6.3f version
well i am stuck here ,,anybody????
the design is simulating successfully in modelsim and  i manually compiled the design, all the files synthesized properly when i separated them but under one top level module design is  not working can anybody tell me whats wrong???
Scholar pratham
if you can simulate a design that does not mean it can be implemented. check in the log reports where you will find out the exact reason. as pointed by vemuld your design is getting fully trimmed.
-Pratham
Newbie ahish
hello,
i'm getting the error "ERROR:Xst:2754 - "E:/mac/fixed_pkg_c.vhdl" line 1019: alias of a function is not supported." when trying to implement fft alogorithm using the fixed_pkg.
Please help me to debug this error.
Historian
Historian
@ahish wrote:
hello,
Deepika gave the answer in the second post in this thread.
