02-08-2019 03:34 AM
I have these 3 warnings about Latch but i don't know how to solve them, can you please help me?
MY CODE IS:
entity Allarme is
Port ( col : in STD_LOGIC_VECTOR(1 to 3);
row : in STD_LOGIC_VECTOR(1 to 4);
p1, p2, f1, f2 : in STD_LOGIC;
clk, rst : in STD_LOGIC;
sys_mod : out STD_LOGIC_VECTOR(1 downto 0);
sirena : out STD_LOGIC);
end Allarme;
architecture Behavioral of Allarme is
type state is (start, activate, allarm);
-- Segnali di appoggio
signal cstate, nstate : state;
signal timeover10 : std_logic :='0';
signal timeover5 : std_logic :='0';
signal count10, ncount10 : integer range 0 to 9;
signal count5, ncount5 : integer range 0 to 4;
signal modality : std_logic_vector(1 downto 0);
begin
up_state : process(clk)
begin
if rising_edge(clk) then
if(rst='1') then
cstate <= start;
count5 <= 0;
count10 <= 0;
else
cstate <= nstate;
count5 <= ncount5;
count10 <= ncount10;
end if;
end if;
end process;
Finite_State_Machine : process(cstate, col, row, p1, p2, f1, f2, timeover10, timeover5)
variable tmp_out : std_logic_vector(1 downto 0);
variable sirena_tmp : std_logic :='0';
begin
case(cstate) is
when start =>
tmp_out :="00";
sirena_tmp := '0';
if(col = "001" and row = "0001") then
tmp_out := "10";
nstate <= activate;
elsif(col = "010" and row = "0001") then
tmp_out := "11";
nstate <= activate;
else
nstate <= start;
end if;
when activate =>
if tmp_out = "10" then -- Siamo nella Modalita' 1
if p1 = '1' then -- Se la Porta 1 viene aperta
if timeover10 = '1' then
nstate <= allarm;
else
nstate <= activate;
end if;
elsif p1 = '0' then
if (p2 = '1' or f1 = '1' or f2 = '1') then -- Se viene aperta la Porta 2 o la/le Finestra/e
if timeover5 = '1' then
nstate <= allarm;
else
nstate <= activate;
end if;
else
nstate <= activate;
end if;
else
nstate <= activate;
end if;
elsif tmp_out = "11" then
if (p2 = '1' or f1 = '1' or f2 = '1') then -- Siamo nella Modalita' 2
nstate <= allarm;
else
nstate <= activate;
end if;
else
nstate <= activate;
end if;
else -- In qualsiasi altro caso
nstate <= activate;
end if;
when allarm =>
sirena_tmp := '1'; -- Attiva la Sirena
if(col = "010" and row = "1000") then -- Se premo 0 sul tastierino, disattivo il Sistema
nstate <= start;
else
nstate <= allarm;
end if;
end case;
sys_mod(1) <= tmp_out(1);
sys_mod(0) <= tmp_out(0);
modality(1) <= tmp_out(1);
modality(0) <= tmp_out(0);
sirena <= sirena_tmp;
end process;
counter_timer10: process(modality, count10)
begin
if (modality = "10") then
if count10 = 9 then
ncount10 <= 0;
timeover10 <= '1';
else
ncount10 <= count10 + 1;
timeover10 <= '0';
end if;
else
ncount10 <= count10;
timeover10 <= '0';
end if;
end process;
counter_timer5: process(modality, count5)
begin
if (modality = "11" or modality = "10") then
if count5 = 4 then
ncount5 <= 0;
timeover5 <= '1';
else
ncount5 <= count5 + 1;
timeover5 <= '0';
end if;
else
ncount5 <= count5;
timeover5 <= '0';
end if;
end process;
end Behavioral;
THE WARNINGS ARE:
WARNING:Xst:737 - Found 1-bit latch for signal <Finite_State_Machine.tmp_out<1>>. Latches may be generated from incomplete case or if statements. We do not recommend the use of latches in FPGA/CPLD designs, as they may lead to timing problems.
WARNING:Xst:737 - Found 1-bit latch for signal <Finite_State_Machine.tmp_out<0>>. Latches may be generated from incomplete case or if statements. We do not recommend the use of latches in FPGA/CPLD designs, as they may lead to timing problems.
WARNING:Xst:737 - Found 1-bit latch for signal <Finite_State_Machine.sirena_tmp>. Latches may be generated from incomplete case or if statements. We do not recommend the use of latches in FPGA/CPLD designs, as they may lead to timing problems.
Thank you!
02-08-2019 04:28 AM
Your FSM is in a combinatorial process and you do not assign tmp_out in every possible if/else structure you have described in that process. The warning messages give a pretty good idea what the problems you have are.
This type of issue is frequenctly cited as an underlying problem with 2-process state machines. However, this can be avoided if you explicitly code values for tmp_out for every condition you have described.
02-08-2019 04:28 AM
02-08-2019 06:57 AM
So i have to code a value for tmp_out for every if and every else that i used in my process only?!
02-08-2019 07:01 AM
Yes - this is because the tmp_out variable is never synchronously assigned (the same for sirena_tmp, as well).
02-08-2019 10:22 AM
It works! Thank you very much.
But now i have 2 more questions:
1) I Have 2 new Warnings:
a) WARNING:Xst:2170 - Unit Allarme : the following signal(s) form a combinatorial loop: GND_3_o_GND_3_o_MUX_11_o, sys_mod<1>.
b) WARNING:Xst:2170 - Unit Allarme : the following signal(s) form a combinatorial loop: sys_mod<0>, GND_3_o_PWR_3_o_mux_38_OUT<0>.
2) I had a simple testbench and i have that my signal 'sirena' turn into 1 after 10( or 5) clks but when clk = '1' and not when clk ='0'. Why?
If you can solve this you will be definitely my hero!
Thank you so much!
THIS IS MY ULTIMATE CODE:
entity Allarme is
end Allarme;
begin
begin
if(rst='1') then
cstate <= start;
count5 <= 0;
count10 <= 0;
else
cstate <= nstate;
count5 <= ncount5;
end if;
end if;
end process;
begin
case(cstate) is
when start =>
tmp_out :="00";
sirena_tmp := '0';
tmp_out := "10";
sirena_tmp := '0';
nstate <= activate;
tmp_out := "11";
sirena_tmp := '0';
nstate <= activate;
else
tmp_out := "00";
sirena_tmp := '0';
nstate <= start;
end if;
when activate =>
tmp_out := "10";
sirena_tmp := '0';
tmp_out := "10";
sirena_tmp := '0';
nstate <= allarm;
else
tmp_out := "10";
sirena_tmp := '0';
nstate <= activate;
end if;
elsif p1 = '0' then
tmp_out := "10";
sirena_tmp := '0';
tmp_out := "10";
sirena_tmp := '0';
tmp_out := "10";
sirena_tmp := '0';
nstate <= allarm;
else
tmp_out := "10";
sirena_tmp := '0';
nstate <= activate;
end if;
else
tmp_out := "10";
sirena_tmp := '0';
nstate <= activate;
tmp_out := "11";
sirena_tmp := '0';
nstate <= activate;
end if;
end if;
else
tmp_out := "10";
sirena_tmp := '0';
nstate <= activate;
end if;
tmp_out := "11";
sirena_tmp := '0';
tmp_out := "11";
sirena_tmp := '0';
tmp_out := "11";
sirena_tmp := '0';
nstate <= allarm;
else
tmp_out := "11";
sirena_tmp := '0';
nstate <= activate;
end if;
else
tmp_out := "11";
sirena_tmp := '0';
nstate <= activate;
end if;
tmp_out := "00";
sirena_tmp := '0';
nstate <= start;
end if;
when allarm =>
tmp_out := "10";
tmp_out := "00";
sirena_tmp := '0';
nstate <= start;
else
tmp_out := "10";
sirena_tmp := '1';
nstate <= allarm;
end if;
tmp_out := "11";
tmp_out := "00";
sirena_tmp := '0';
nstate <= start;
else
tmp_out := "11";
sirena_tmp := '1';
nstate <= allarm;
end if;
else
tmp_out := "00";
sirena_tmp := '0';
nstate <= start;
end if;
end case;
end process;
counter_timer10: process(p1, count10)
begin
if (p1 = '1') then
if count10 = 9 then
ncount10 <= 0;
timeover10 <= '1';
else
timeover10 <= '0';
end if;
else
timeover10 <= '0';
end if;
end process;
counter_timer5: process(p2,f1,f2, count5)
begin
if (p2 = '1') then
if count5 = 4 then
ncount5 <= 0;
timeover5 <= '1';
else
timeover5 <= '0';
end if;
elsif (f1 = '1') then
if count5 = 4 then
ncount5 <= 0;
timeover5 <= '1';
else
timeover5 <= '0';
end if;
elsif (f2 = '1') then
if count5 = 4 then
ncount5 <= 0;
timeover5 <= '1';
else
timeover5 <= '0';
end if;
else
ncount5 <= count5;
timeover5 <= '0';
end if;
end process;
end Behavioral;
AND THIS IS MY TB (In this case when f1 <= '1', after 5clks(when clk <= '0') sirena <= '1' but in my case, after 5clks sirena <='1' (but when clk <= '1' ):
LIBRARY ieee;
USE ieee.std_logic_1164.ALL;
use ieee.std_logic_arith.all;
-- Uncomment the following library declaration if using
-- arithmetic functions with Signed or Unsigned values
--USE ieee.numeric_std.ALL;
ENTITY TB_Allarme IS
END TB_Allarme;
ARCHITECTURE behavior OF TB_Allarme IS
-- Component Declaration for the Unit Under Test (UUT)
COMPONENT Allarme
PORT(
col : IN std_logic_vector(1 to 3);
row : IN std_logic_vector(1 to 4);
p1 : IN std_logic;
p2 : IN std_logic;
f1 : IN std_logic;
f2 : IN std_logic;
clk : IN std_logic;
rst : IN std_logic;
sys_mod : OUT std_logic_vector(1 downto 0);
sirena : OUT std_logic
END COMPONENT;
--Inputs
signal col : std_logic_vector(1 to 3) := (others => '0');
signal row : std_logic_vector(1 to 4) := (others => '0');
signal p1 : std_logic := '0';
signal p2 : std_logic := '0';
signal f1 : std_logic := '0';
signal f2 : std_logic := '0';
signal clk : std_logic := '0';
signal rst : std_logic := '0';
--Outputs
signal sys_mod : std_logic_vector(1 downto 0);
signal sirena : std_logic;
-- Clock period definitions
constant clk_period : time := 10 ns;
BEGIN
-- Instantiate the Unit Under Test (UUT)
uut: Allarme PORT MAP (
col => col,
row => row,
p1 => p1,
p2 => p2,
f1 => f1,
f2 => f2,
clk => clk,
rst => rst,
sys_mod => sys_mod,
sirena => sirena
-- Clock process definitions
clk_process :process
begin
clk <= '0';
wait for clk_period/2;
clk <= '1';
end process;
-- Stimulus process
stim_proc: process
begin
-- Sequenza di reset
rst <= '1';
wait for clk_period;
rst <= '0';
col <= "001";
row <= "0001";
f1 <= '1';
wait for 15*clk_period;
col <= "010";
row <= "1000";
wait;
end process;
END;
02-10-2019 11:45 PM
You seem to be a little unsure about the logic that you are describing. There is a mix of synchronous and combinatorial logic in your source code (nothing wrong with that, per se - very common) but your expectations of what you want your logic to do are a little skewed.
I took your code and simulated it. To take you queries one by one:
1. Do you understand that sys_mod(1) is exactly the same signal as tmp_out(1)? It is asynchornously assigned in your combinatorial FSM process. Now, within that process, you are also testing for the condition of tmp_out and making subsequent assignments to the signal as a result of the test. In the activate state you firstly test if tmp_out = "10", then later test if tmp_out = "11" or otherwise assign tmp_out <= "00". So if tmp_out = "01", it will combinatorially become "00". This is a combinatorial loop.
2. Essentially the same as above.
I don't really understand why tmp_out is a variable. Why not make it a signal and register it in your synchronous process, then test for the condition of the synchronous signal? This is, as I understand it, the point of a two-process state machine.
I haven't investigated too closely but I suspect that sirena <= '1' on this rising edge of the clock because your state machine is sensitive to the synchronous version of the state (cstate). In the simulation cstate <= allarm on the rising edge of the clock and only then are all of the simulation conditions met to affect the sirena output.
02-10-2019 11:55 PM
All clear, thanks a lot!
02-11-2019 07:28 AM - edited 02-11-2019 07:28 AM
Hi @a.zeoli3,
Please close the thread if your issue has been resolved, by marking it as accepted solution.
