Visitor heller390
getting "U" in some outputs during simulation
Hello I am new to Xilinx.Basically I am implementing a 1784 bit interleaver and deinterleaver using CCSDS algortihm.I want to check whether they are right.So i module instantiated both interleaver and deinterleaver files by writing a wrapper file and then gave some test input.Everything works fine except that I am getting 5 outputs as "UNINITIALIZED" out of 1784.I tried debugging but cant identify the problem.Please kindly help me solve the issue
Re: getting "U" in some outputs during simulation
HI @heller390
This can happen in  VHDLbehavioural simulations in genreral, if one of the drivers of the signal you are monitoring is unintialized. Please  initialize them to "Z" in your RTL.. (use  :=(others => 'Z'), if it is a bus ).
Is the post-synth simulation working fine?
Bharath
Please mark the Answer as "Accept as solution" if information provided addresses your query/concern.
Are you doing behavioural simulation or post synthesis simulation? does your deisgn work in behavioural simulation?
-Shreyas
Try to search answer for your issue in forums or xilinx user guides before you post a new thread.
Kindly note- Please mark the Answer as "Accept as solution" if information provided solves your query.
Give Kudos (star provided in right) to a post which you think is helpful and reply oriented.
HI @heller390
Bharath
Visitor heller390
Thanks for the reply guys.I am doing behavioural implemenatation after going through the process of checking behavioural syntax.syntax is fine.But i get some op as U.
Visitor heller390
Thanks for the solution.The design is working fine after initiliazing as u said.Once again thanks for helping me .
HI @heller390
Glad to know. this happens  in VHDL  behavioural simulation.if a signal has two drivers 'U' and '1'/'0'. The resultant output will 'U'.
You will not find this problem in post-synth simulations.
It is a good practice initialize driver signals to 'Z' instead of leaving them unintialized in VHDL.
Bharath
Visitor rubana
I have a few data lines in my program and for all the "inout" signal types i am getting uninitialised result? However, if i change these data lines to either output or input i am getting the result? Does isim not support "inout" port?
HI @rubana
Always create new thread for your query and for more visibility.
As explained in this post, this behaviour is typical VHDL behavioural simulation of inout signals , please initialize the inout signals to "Z" value as mentioned above and try.
Bharath
Observer abdelkader
hI?
I am working on interleaver implementation, can you please mention a link of your project or a report about how to implement it?
Thank you
