tchin123
Voyager
Voyager
hierarchical name with MARK_DEBUG
Does hierarchical naming convention work with Mark_debug:
If I have a design called TOP and it contains a instance called Decode_instA and inside this another instance called CPU_instB.
Within this module there is a signal/wire called XYZ. Will Vivado accept this when declared within TOP ?
(* mark_debug = "true" *) wire Decode_instA/CPU_instB/XYZ;
I try this out and it didn't work.
Does this work or is the syntax different?
hpoetzl
Voyager
Voyager
Hey @tchin123,
Hierarchical name support is not that good in Vivado yet.
Why not do it in TCL where you have access to all the defined nets, pins and ports?
Best,
Herbert
-------------- Yes, I do this for fun!
vijayak
Hi @tchin123
Check the below document for supported list.
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2017_2/ug901-vivado-synthesis.pdf page 228
Thanks,Vijay
vemulad
Hi @tchin123
You can apply the mark_debug attribute on hierarchical net names from XDC file.
Deepika.
