luoyanghero
how can I change the ram resource type when instance different size?
I use vivado 2016.03. I have a ram model as follow, this model will instance many times with different parameters. such as SIZE=8, 16, 32, 40, 100, 200, 500, ...
In default synthesis settings, I tested , when SIZE < 256; vivado will use register to build the ram model, when SIZE>256 vivado will use block ram to build the ram model.
My question is, how can I change the setting, for example, when SIZE>50 use block ram.
luoyanghero
Just use coregen, it is the best way to control use which utilization.
drjohnsmith
these might help
https://www.xilinx.com/support/answers/46515.html
And here page 76
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_2/ug953-vivado-7series-libraries.pdf
if you instantiate the macro , then you can control this ,
graces
You can use RAM_STYLE attribute to instruce the Vivado synthesis tool on how to infer memory.
Accepted values are:
• block: Instructs the tool to infer RAMB type components.
• distributed: Instructs the tool to infer the LUT RAMs.
• register: Instructs the tool to infer registers instead of RAMs.
• ultra: Instructs the tool to use the Zynq UltraScale+ URAM primitives.
e.g.
(* ram_style = “block”*) reg signed [14:0]   memory[SIZE];
If starting with Versal take a look at our Versal Design Process Hub and our Versal Blogs.
luoyanghero
I made a test as your description, but is not my expect.
I use IP core-gen generate 4 different type fifo(‘block ram’, ‘distributed ram’, ‘shift register’, ‘builtin fifo’), after synthesis and implementation, the resource is my expect: ‘builtin fifo’ and ‘block ram’ use ‘Block RAM Tile’ resources, ‘distributed ram’ and ‘shift register’ use LUT resources.
Then I use my ‘SYN_FIFO’ module, and add ‘(* ram_style = *)’ to my register memory define, and instance them to different depth from 16 to 1024, they are all use LUT resources, no ‘Block RAM’ resouces.
This is my SYN_FIFO_S code:
`ifndef DLY
`define DLY	1
`endif
module SYN_FIFO_S(
    clk_bus, brst_n, start_rst, fifo_wr, fifo_wdata, fifo_rd,
    fifo_full, almost_full, fifo_rdata, fifo_emp);
parameter	DEPTH = 8;
parameter	AW	  = 3;
parameter	DW	  = 32;
input					clk_bus;
input					brst_n;
input					start_rst;
input					fifo_wr;
input[DW-1:0]			fifo_wdata;
output					fifo_full;
output					almost_full;
input					fifo_rd;
output[DW-1:0]			fifo_rdata;
output					fifo_emp;
reg  [AW:0]				fifo_cnt;
reg  [AW-1:0]           fifo_raddr;
(* ram_style = "register"*)    reg  [DW-1:0]     fifo_reg[0:DEPTH-1];
reg  [AW-1:0]           fifo_waddr;
wire [DW-1:0]			fifo_rdata;
wire					fifo_emp;
wire					fifo_full;
always @ (posedge clk_bus or negedge brst_n) begin
	if (~brst_n)
		fifo_cnt[AW:0] <= #`DLY {(AW+1){1'b0}};
	else if (start_rst)
	else if (fifo_rd && fifo_wr)
		fifo_cnt[AW:0] <= #`DLY fifo_cnt;
	else if (fifo_rd)
		fifo_cnt[AW:0] <= #`DLY fifo_cnt - 1'b1;
	else if (fifo_wr)
		fifo_cnt[AW:0] <= #`DLY fifo_cnt + 1'b1;
end
	if (~brst_n)
		fifo_waddr[AW-1:0] <= #`DLY {AW{1'b0}};
	else if (start_rst)
	else if (fifo_wr)
		fifo_waddr[AW-1:0] <= #`DLY (fifo_waddr == DEPTH-1'b1) ? {AW{1'b0}} : fifo_waddr + 1'b1;
end
	if (~brst_n)
		fifo_raddr[AW-1:0] <= #`DLY {AW{1'b0}};
	else if (start_rst)
	else if (fifo_rd)
		fifo_raddr[AW-1:0] <= #`DLY (fifo_raddr == DEPTH-1'b1) ? {AW{1'b0}} : fifo_raddr + 1'b1;
end
assign fifo_rdata[DW-1:0] = fifo_reg[fifo_raddr];
always @ (posedge clk_bus) begin
	if (fifo_wr)
		fifo_reg[fifo_waddr] <= #`DLY fifo_wdata;
end
assign fifo_emp  = (fifo_cnt == 0);
assign fifo_full = (fifo_cnt == DEPTH);
assign almost_full = (fifo_cnt >= DEPTH - 1);
endmodule
in SYN_FIFO_M code, everything is same with SYN_FIFO_S except this:
(* ram_style = "distributed"*) reg  [DW-1:0]     fifo_reg[0:DEPTH-1];
in SYN_FIFO_L code, everything is same with SYN_FIFO_S except this:
(* ram_style = "block"*)       reg  [DW-1:0]     fifo_reg[0:DEPTH-1];
This is my implementation resource result:
luoyanghero
