Voyager
Voyager
how not to be extracted RAM,only register array?
like synplify:
reg  [31:0] memory  [8:0]   /* synthesis syn_ramstyle="registers" */;
I hope it will be register array,not any ram. Or,how not to be extracted RAM,only register by XST?
You can set ram_extract to NO. This attribute can be applied globally via synthesis settings. or it can be applied on specific signal/module/entity in HDL. Refer to page-412 0f http://www.xilinx.com/support/documentation/sw_manuals/xilinx14_2/xst_v6s6.pdf
The page-465 of this guide gives synplify equivalent attributes in ISE, see below
Deepika.
Deepika.
This looks to be a similar question given in the below link
http://forums.xilinx.com/t5/Synthesis/how-to-synthesize-a-memory-with-register-style-not-blockram/m-p/392471/highlight/false#M9740
If yes can we have one of the post marked as accepted solution if the question has been answered?
Hem
