how to find most frequent element in an array in verilog code
I  want to get the most frequent element in an array, for example , an array [1,2,1,3,1,4,1,5], the most frequent element is 1. but how to write the code ?
I referred other language to find the most frequent element , if have any error ,please tell me.
wire [21:0] A  [0:7];
reg [16:0] curr_count=1;
reg [16:0] max_count=1;
reg [16:0] res= A[0];
integer i;
always @ (posedge CLK )
begin
if (RST_X)
begin
for(i=0; i<7; i=i+1)
begin
curr_count <= 0;
end
end
else if ( A[i]==A[i-1])
begin
curr_count <= curr_count+1;
end
else if ( curr_count> max_count)
begin
max_count <= curr_count;
res <= A[i - 1];
end
end
Im not sure the following syntax.
//else if ( A[i]==A[i-1])
begin
end//
I think this syntax just stated to compare with Whether the adjacent numbers are equal.
who can help me to correct this code ?
Mentor
Mentor
What you need is called a Histogram function..   After computing the histogram, then it's a matter of finding the histogram index with the highest value.
Here is an example of VHDL that implements a histogram function.   you can then add an output stage that finds the peak value of the histogram.
Now of course your target language is verilog, but this some elbow grease, you should be able to convert from VHDL to verilog.
good luck!
John
Mentor
Mentor
good luck!
John
