how to make the synthesizer work with a clock
hi
i wrote a vhdl code and I have three clks as clk,clk2x,clk4x in my code. when I synthesize the code i have this line in report
Timing constraint: Default period analysis for Clock 'clk4x'
how could I make it give clk as default?
thanks
Professor
Professor
You should have similar lines for all clocks actually used in the design.  Note that you only get a "default period analysis" for clocks that have paths internal to the FPGA going from one flip-flop's Q, possibly though logic, to another flip-flop's D.  Otherwise there is no "period" that relates to a path that can be checked for timing.
-- Gabor
I have one clk=20 ns that go through all design ,but in one part i want 4 times of my clock,because of that i made another port and clk4x and made it 1.25 ns.
now when I want to synthesize it I dont have synthesize report for cllk just for clk4x
Professor
Professor
Without looking at the design, it's hard to say why, but most likely you don't have any flops clocked by the 20 ns clock whose output is used by other flops on that clock.  Without such a path, you won't see a period analysis.  You can open the RTL schematic to see if the original 20 ns clock is still in the design, and if so what it actually clocks.
-- Gabor
Hi @milan.km,
Please attach your code and constraints file here.
You are dividing the frequency or multiplying?
Arpan
Arpan
Hi @milan.km
Just as a check, do ensure you have written proper clock period constraints.
You can find information regarding all the constraints in http://www.xilinx.com/itp/xilinx10/books/docs/cgd/cgd.pdf
Please share the constraint file along with the relevant code as requested above.
Tushar.
Why you are trying to use FPGA fabric to generate clocks?
This is not recommended practice to generate the clock. You can use DCM/PLL/MMCM (clock modulation blocks) to achive the functionality.
Which Device you are targetting?
Yash
this is the main code
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use ieee.numeric_std.all;
entity full is
port(p_1,p_2,p_3,p_4 : in unsigned(7 downto 0);
clk : in std_logic;
clk2x : in std_logic;
clk4x : in std_logic;
p_out : out unsigned(7 downto 0));
end full;
architecture full_arch of full is
component main is
port(pxin : in unsigned(7 downto 0);
clk : in std_logic;
pxo : out unsigned(7 downto 0));
end component;
component reg is
port(p1,p2,p3,p4 : in unsigned(7 downto 0);
     clk : in std_logic;
	  mo : out unsigned(7 downto 0));
end component;
signal po_int : unsigned(7 downto 0) := "00000000";
begin
f1 : component reg
     port map (p1 => p_1, p2 => p_2, p3 => p_3, p4 => p_4 , clk => clk, mo => po_int);
f2 : component main
     port map (pxin => po_int, clk => clk , clk2x => clk2x , clk4x => clk4x , pxo => p_out);
end full_arch;
clk= 20 ns,clk2x=5 ns,clk4x=1.25 ns.
for the main code :
Timing constraint: Default period analysis for Clock 'clk'
  Clock period: 5.211ns (frequency: 191.902MHz)
  Total number of paths / destination ports: 48474 / 7198
Delay:               5.211ns (Levels of Logic = 8)
  Source:            f1/c1/r3/j_2 (FF)
  Destination:       f1/c1/r3/t3_7 (FF)
  Source Clock:      clk rising
  Destination Clock: clk rising
Timing constraint: Default period analysis for Clock 'clk2x'
  Clock period: 3.758ns (frequency: 266.099MHz)
  Total number of paths / destination ports: 484 / 122
Delay:               3.758ns (Levels of Logic = 3)
  Source:            f2/d1/ena1 (FF)
  Destination:       f2/d1/ena3 (FF)
  Source Clock:      clk2x rising
  Destination Clock: clk2x rising
  Clock period: 4.203ns (frequency: 237.925MHz)
  Total number of paths / destination ports: 2806 / 385
Delay:               4.203ns (Levels of Logic = 4)
  Source:            f2/d2/ad1_7 (FF)
  Destination:       f2/d2/Mram_buff1 (RAM)
  Source Clock:      clk4x rising
  Destination Clock: clk4x rising
--------------------------this is for "reg" component---------------------
Speed Grade: -1
   Minimum period: 5.211ns (Maximum Frequency: 191.902MHz)
   Minimum input arrival time before clock: 1.567ns
   Maximum output required time after clock: 6.942ns
   Maximum combinational path delay: No path found
Timing Detail:
All values displayed in nanoseconds (ns)
--------------------------------------------this is for "main" component ----------------
Timing Summary:
Speed Grade: -1
   Minimum period: 3.530ns (Maximum Frequency: 283.286MHz)
   Minimum input arrival time before clock: 1.159ns
   Maximum output required time after clock: 3.259ns
Timing Detail:
  Clock period: 3.530ns (frequency: 283.286MHz)
  Total number of paths / destination ports: 2800 / 321
Delay:               3.530ns (Levels of Logic = 3)
  Source:            d2/ad1_4 (FF)
  Destination:       d2/Mram_buff1 (RAM)
  Data Path: d2/ad1_4 to d2/Mram_buff1
                                Gate     Net
    Cell:in->out      fanout   Delay   Delay  Logical Name (Net Name)
     FD:C->Q              10   0.471   1.022  d2/ad1_4 (d2/ad1_4)
     LUT5:I0->O            4   0.094   0.496  d2/ad1_mux0001<5>11 (d2/N9)
     LUT5:I4->O            1   0.094   0.576  d2/ad1_mux0001<9>_SW0 (N36)
     LUT6:I4->O            1   0.094   0.336  d2/ad1_mux0001<9> (d2/ad1_mux0001<9>)
     RAMB18:ADDRB12            0.347          d2/Mram_buff1
    Total                      3.530ns (1.100ns logic, 2.430ns route)
                                       (31.2% logic, 68.8% route)
  Clock period: 2.954ns (frequency: 338.524MHz)
  Total number of paths / destination ports: 505 / 80
Delay:               2.954ns (Levels of Logic = 3)
  Source:            d1/adr3_0 (FF)
  Destination:       d1/adr3_9 (FF)
  Data Path: d1/adr3_0 to d1/adr3_9
                                Gate     Net
     FD:C->Q               4   0.471   1.085  d1/adr3_0 (d1/adr3_0)
     LUT6:I0->O            1   0.094   0.480  d1/ena1_not00011_SW0_SW0 (N38)
     LUT6:I5->O           12   0.094   0.636  d1/ena1_not00011 (d1/adr3_and0000)
     LUT4:I2->O            1   0.094   0.000  d1/adr3_9_rstpot (d1/adr3_9_rstpot)
     FD:D                     -0.018          d1/adr3_9
    Total                      2.954ns (0.753ns logic, 2.201ns route)
                                       (25.5% logic, 74.5% route)
Timing constraint: Default OFFSET IN BEFORE for Clock 'clk2x'
  Total number of paths / destination ports: 16 / 16
Offset:              1.159ns (Levels of Logic = 1)
  Source:            pxin<7> (PAD)
  Destination:       d1/pi3_7 (FF)
  Data Path: pxin<7> to d1/pi3_7
                                Gate     Net
     IBUF:I->O             2   0.818   0.341  pxin_7_IBUF (pxin_7_IBUF)
     FDE:D                    -0.018          d1/pi1_7
    Total                      1.159ns (0.818ns logic, 0.341ns route)
                                       (70.6% logic, 29.4% route)
Timing constraint: Default OFFSET OUT AFTER for Clock 'clk4x'
  Total number of paths / destination ports: 8 / 8
Offset:              3.259ns (Levels of Logic = 1)
  Source:            d2/m/pou_7 (FF)
  Destination:       pxo<7> (PAD)
  Data Path: d2/m/pou_7 to pxo<7>
                                Gate     Net
     FDS:C->Q              1   0.471   0.336  d2/m/pou_7 (d2/m/pou_7)
     OBUF:I->O                 2.452          pxo_7_OBUF (pxo<7>)
    Total                      3.259ns (2.923ns logic, 0.336ns route)
                                       (89.7% logic, 10.3% route)
I also cant understand why the clk frequency for the main code and for the reg conponent is the same.what about the main conponent?
Hi @milan.km,
Have you applied any timing constraints on the clock signals?
Please share the code for reg and main.
Arpan
Arpan
no I didnt put any constraints.and I dont know how to do it.
reg
---------------- reg & add
library IEEE;
entity reg is
     clk : in std_logic;
end reg;
architecture reg_syn of reg is
component corereg is
    Port ( pr : in  unsigned (7 downto 0);
           pi : in  unsigned (7 downto 0);
           clk : in  STD_LOGIC;
           pmi : out  unsigned (7 downto 0));
end component;
signal m1,m2,m3 : unsigned(7 downto 0) := (others => '0');
signal int_m : unsigned(9 downto 0) := (others => '0');
component ram2 is
port (Clk : in std_logic;
        --address : in integer range 0 to 4095;
        we : in std_logic;
        di : in unsigned(7 downto 0);
        do : out unsigned(7 downto 0));
end component;
signal po : unsigned(7 downto 0) := "00000000";
signal wre : std_logic := '0';
begin
 c1 : component corereg
      port map(pr => p1, pi => p2, clk => clk,pmi => m1 );  --ref image
 c2 : component corereg
      port map(pr => p1, pi => p3, clk => clk,pmi => m2 );  --pic1
 c3 : component corereg
      port map(pr => p1, pi => p4, clk => clk,pmi => m3 );  --pic2
 c4 : component ram2
      port map(clk => clk, we => wre, di => p1, do => po );
		process(clk,m1,m2,m3)
		variable sum_p : unsigned(9 downto 0) := "0000000000";
		begin
		sum_p := "00"&po + m1 + m2 + m3;
		mo <= sum_p(9 downto 2);
		end process;
		end reg_syn;
main
library IEEE;
entity main is
clk : in std_logic;
end main;
architecture Behavioral of main is
component interpol1 is
port(clk : in std_logic;
     pin : in unsigned(7 downto 0);
	  pout: out unsigned(7 downto 0));
end component;
component mean2 is
port( pi  : in unsigned(7 downto 0);
      clk : in std_logic;
		po : out unsigned(7 downto 0));
		--p1,p2,p3,p4,p5,p6,p7,p8,p9  : buffer signed(7 downto 0));
end component;
begin
d1 : component interpol1
     port map (clk => clk, clk2x=> clk2x, clk4x => clk4x,pin => pxin,pout => po_int);
d2 : component mean2
	  port map (clk => clk4x, pi => po_int , po => pxo);
end Behavioral;
Hi @milan.km,
We have to put constraints to make the tool understand our timing requirements.
For constraining the clock follow the following steps:
1.Go to Tools->Constraints editor in ISE project navigator.(snapshot-1)
2.Click on the unconstrained clock say "clk".(snapshot-2)
3. Give the clock period in the time (snapshot-3)
4.Save the changes(snapshot-4)
5.Click on design and go through .ucf file to see the constraints(snapshot-4 and 5)
6.Run implementation and then see the static timing report.
Please go through the following video. Hope it will be helpful to you.
https://www.youtube.com/watch?v=KF4EVN93EFI
Arpan
Arpan
thanks @arpansur.it was so help ful.
can u help me with "why the main code and the reg component have the same frequency"?
I checked them all,they work properly.but I dont know ehy the clks are the same,what about the main component it should make the critical path longer and decrease the frequency.
dear @arpansur
I also wanted to ask if I have more than one clk as u see in my code.
clk=20
clk2x=5
clk4x=1.25
and I want to have a report of clock of sysyem which one should be selected?
I mean which one is logical?
and the maximum freq based on each of clks(clk,clk2x,xlk4x) is diffrent?
Hi @milan.km,
Have you applied the constraints?
Is it showing same frequency after constraint is applied to it?
Is it you are talking about net delay?
If so please don't be confused between net delay and clock period.
Arpan
Arpan
Hi @milan.km,
If you are constraining all the clocks then all are reported in timing report.
Is it your concern?(correct me if I am wrong)
Arpan
Arpan
yes they are the same.
and when I did this for the main component and I SELECT clk as my constraint,I just have report for clk2x and clk4x and not for clk
I want to get ris of problems of working with multiple clks, do u think that would be ok to put clk4x as my input.
and make clk2x and clk by clk deviding,
do u think thats a goot idea??? because I think working with multiple clks have some problems
Hi @milan.km,
Yes you can go with a single clock and generate multiple clocks out of it.
If you want to go for frquency divider a simple counter will help and if you want to go for freuency multiplier then DCM/PLL will be helpful.
Arpan
Arpan
