alstonl
i want to synthesis a simple project, but failed
start_gui
open_project C:/Users/lenovo/Desktop/vivado/project_1.xpr
Scanning sources...
Finished scanning sources
INFO: [IP_Flow 19-234] Refreshing IP repositories
INFO: [IP_Flow 19-1704] No user IP repositories specified
INFO: [IP_Flow 19-2313] Loaded Vivado IP repository 'E:/vivado/Vivado/2017.4/data/ip'.
open_project: Time (s): cpu = 00:00:13 ; elapsed = 00:00:13 . Memory (MB): peak = 766.676 ; gain = 69.574
update_compile_order -fileset sources_1
reset_run synth_1
launch_runs synth_1 -jobs 2
[Fri Mar 30 10:48:41 2018] Launched synth_1...
Run output will be captured here: C:/Users/lenovo/Desktop/vivado/project_1.runs/synth_1/runme.log
hemangd
Hi @alstonl,
If your question is answered and/or your issue is solved, please mark a response that resolved your issue, as Accepted Solution (more info on this can be found here: https://forums.xilinx.com/t5/help/faqpage/faq-category-id/solutions#solutions). This way, the topic can be completed then.
If this is not solved/answered, please reply in the thread.
Thanks in advance and have a great day.
hemangd
hemangd
Hi @alstonl,
Provide the synthesis runme.log which will be stored here C:/Users/lenovo/Desktop/vivado/project_1.runs/synth_1/runme.log
Which will show the specific error which you are facing in synthesis phase.
hemangd
hemangd
alstonl
*** Running vivado
    with args -log abs_dif.vds -m64 -product Vivado -mode batch -messageDb vivado.pb -notrace -source abs_dif.tcl
****** Vivado v2017.4 (64-bit)
  **** SW Build 2086221 on Fri Dec 15 20:55:39 MST 2017
  **** IP Build 2085800 on Fri Dec 15 22:25:07 MST 2017
    ** Copyright 1986-2017 Xilinx, Inc. All Rights Reserved.
source abs_dif.tcl -notrace
Command: synth_design -top abs_dif -part xc7a35tcsg325-1
Starting synth_design
Attempting to get a license for feature 'Synthesis' and/or device 'xc7a35t'
INFO: [Common 17-349] Got license for feature 'Synthesis' and/or device 'xc7a35t'
INFO: Launching helper process for spawning children vivado processes
INFO: Helper process launched with PID 2548
Starting Synthesize : Time (s): cpu = 00:00:06 ; elapsed = 00:00:06 . Memory (MB): peak = 345.473 ; gain = 101.273
INFO: [Synth 8-638] synthesizing module 'abs_dif' [C:/Users/lenovo/Desktop/新建文件夹/scr/abs_dif.v:1]
INFO: [Synth 8-638] synthesizing module 'comp' [C:/Users/lenovo/Desktop/新建文件夹/scr/comp.v:1]
 Parameter n bound to: 4 - type: integer
INFO: [Synth 8-256] done synthesizing module 'comp' (1#1) [C:/Users/lenovo/Desktop/新建文件夹/scr/comp.v:1]
INFO: [Synth 8-638] synthesizing module 'mux_2to1' [C:/Users/lenovo/Desktop/新建文件夹/scr/mux_2to1.v:1]
INFO: [Synth 8-256] done synthesizing module 'mux_2to1' (2#1) [C:/Users/lenovo/Desktop/新建文件夹/scr/mux_2to1.v:1]
INFO: [Synth 8-638] synthesizing module 'full_adder' [C:/Users/lenovo/Desktop/新建文件夹/scr/full_adder.v:1]
INFO: [Synth 8-256] done synthesizing module 'full_adder' (3#1) [C:/Users/lenovo/Desktop/新建文件夹/scr/full_adder.v:1]
INFO: [Synth 8-256] done synthesizing module 'abs_dif' (4#1) [C:/Users/lenovo/Desktop/新建文件夹/scr/abs_dif.v:1]
TclStackFree: incorrect freePtr. Call out of sequence?
hemangd
Hi @alstonl,
Can you check your computer name?
Error might be caused by cyrillic letters in computer name.
 i.e.:  Use "User-PC" instead  "User-ПК".
And also i can see that your paths are like this: C:/Users/lenovo/Desktop/新建文件夹/scr/comp.v
Try with only English letters and check as it seems a different language.
hemangd
hemangd
alstonl
hemangd
Hi @alstonl,
hemangd
