onkarkk1
loop iteration limit
Hi ,
While doing synthesis of my design im getting following error:::::
Xst:2636 - "f3.v" line 32: Loop has iterated 10000 times. Use "set -loop_iteration_limit XX" to iterate more.
i have tried setting loop iteration limit using tcl console but no use....
I am using ISE 10.1.3 on debian(lenny)..
could any one please help me ......
regards
Krishna Kishore
onkarkk1
hi sorry,
i got the solution ...
regards
Krishna Kishore
priyamp
onkarkk1
add -loop_iteration_limit  XX    XX may be any number depends on ur loop count in the .xst file in ur project folder and compile it will work....
bassman59
Historian
Historian
I would worry about this error and changing this limit. It usually means something bad.
onkarkk1
As i have learnt , the tool has default limit of 64 for loop count ( any loop) , if it execeeds that then it will give this error, to over come this one has to set this attribute in .xst file.
Please correct me if i am wrong.
regards
Krishna Kishore
bassman59
Historian
Historian
regards
Krishna Kishore
I don't know what the actual limit is, but this is the sort of error you get when you synthesize a big combinatorial loop.
shazni
Hello onkarkk1
I also have the same problem now. You have post this thread in last year. You have said you solved it. I also understand that I need to add  set -loop_iteration_limit XX in .xst file in project folder. In my case XX should be 32768 iteartions. I did it so. But still the same issue.
I need a bit descriptive answer from you. It's really urgent. It be very mush appreciable if you can explain me this in case I'm doing some silly mistake. Do I need to append just the above line in the .xst? What else I need to do?
onkarkk1
might be u r using gui for compilation , if that is the case as i remember it didnt work for me too , more over it will overwrite your settings. Actually i have used a script for compilation, i.e., xst manual there u will get for  every procees there will be a command based on that i have written a script and it worked for me..
regards
krish
shazni
Thank you onkarkk1
Thanks. Sorry for the late reply. I was on leave. Anyway I solved the issue in another way. In fact it's not a method. This error comes, because  'for loop exceeds the limit. I still didn't solve for 'for' loop. I omit the for loop, since I really don't want an initialization process as I'm not gonna use the initial values in my algorithms. For loops are mostly used in initialization rather than for the algorithm itself in Verilog.
satya0428
I have similar problem . But I dont have any loops (while or for) in the code , and still i m having this problem. Is there might be any other reason for this error, please let me know if any one about this. Also,I could not understand the procedure of increasing the loop limit using ise simulator , thanks for your reply.
viviany
I suggest you post your own questions in a new message. You can add the link to this thread in your message to let others know this is a similar issue as what you have.
You mentioned ISE Simulator. So did you meet this problem in ISE Simulator? If so, you should post your question on the "Simulation" board.
And please post the error message you met, and the HDL file in which the error occurred if possible. This will help others understand the problem and give you suggestions.
Vivian
如果提供的信息能解决您的问题,请标记为“接受为解决方案”。
如果您认为帖子有帮助,请点击“奖励”。谢谢!
shuklaankita
hello sir
I do have the same problem I am trying to pass a 3x3 filter over an image of size 240x160. Its obvious about the loop problem  I had used the given suggestions but it doesnot work out
