max_fanout sometimes doesn't work in Verilog
I am using Vivado 216.3 with default settings. The attribute max_fanout works in general, but on one signal it doesn't:
(*max_fanout= 8*) reg  lastNow;
I see no message in synthesis report and timing  reports says fanout 24;  (I would expect 26)
When I change the value to 2, then I do see a message in synthesis report: Fanout is changed from 3 to 2. In timing report it is 24 again. :-)
My guess is that XST makes two internal copies of the signal and assigns the fanout to one of them.
How can I avoid this?
When I replicate the register manually (using dont_touch), timing closes and everything is fine.
Re: max_fanout sometimes doesn't work in Verilog
@nupurs wrote:
@uncle_tim,
see if this AR helps:
https://www.xilinx.com/support/answers/62162.html
No, sorry. It't all in one hierarchy.
I think I have found it. In my opinion this is a bug in XST.
The problem is caused by an inverted clock enable. XST seems to make two signals internally: one inverted and one not inverted. This causes the attribute not to propagate properly.
The following code reproduces the problem.
module Combiner
    input wire sysClk,
    input wire [6:0] tag,
    input wire  [16:0] tcounter,
    input wire now,
    output reg [23:0] combinedTag,
    output reg combinedTagWr
(* max_fanout= 2 *)reg  lastNow;
@always @(posedge sysClk) begin
    if (!lastNow)
        combinedTag<=  {tcounter, tag};
    combinedTagWr<=now  | lastNow;
    lastNow<= now & !lastNow;
end
endmodule
From synth report:
INFO: [Synth 8-4618] Found max_fanout attribute set to 2 on net lastNow. Fanout reduced from 3 to 2 by creating 1 replicas.
Timing says fanout 24.
When you remove the inversion in "if (!lastNow)", the problem goes away.
@uncle_tim,
Nupur
@nupurs wrote:
@uncle_tim,
Sorry, no.
The signal is not going to a different hierarchy.
It is defined locally in a for loop within a generate block.
When I set max_fanout to 2, I get this in synthesis:
INFO: [Synth 8-4618] Found max_fanout attribute set to 2 on net p_0_in12_in. Fanout reduced from 3 to 2 by creating 1 replicas.
INFO: [Synth 8-4618] Found max_fanout attribute set to 2 on net p_0_in15_in. Fanout reduced from 3 to 2 by creating 1 replicas.
INFO: [Synth 8-4618] Found max_fanout attribute set to 2 on net p_0_in18_in. Fanout reduced from 3 to 2 by creating 1 replicas.
INFO: [Synth 8-4618] Found max_fanout attribute set to 2 on net p_0_in21_in. Fanout reduced from 3 to 2 by creating 1 replicas.
INFO: [Synth 8-4618] Found max_fanout attribute set to 2 on net p_0_in24_in. Fanout reduced from 3 to 2 by creating 1 replicas.
INFO: [Synth 8-4618] Found max_fanout attribute set to 2 on net p_0_in27_in. Fanout reduced from 3 to 2 by creating 1 replicas.
INFO: [Synth 8-4618] Found max_fanout attribute set to 2 on net p_0_in9_in. Fanout reduced from 3 to 2 by creating 1 replicas.
INFO: [Synth 8-4618] Found max_fanout attribute set to 2 on net p_0_in30_in. Fanout reduced from 3 to 2 by creating 1 replicas.
INFO: [Synth 8-4618] Found max_fanout attribute set to 2 on net p_0_in33_in. Fanout reduced from 3 to 2 by creating 1 replicas.
INFO: [Synth 8-4618] Found max_fanout attribute set to 2 on net p_0_in36_in. Fanout reduced from 3 to 2 by creating 1 replicas.
INFO: [Synth 8-4618] Found max_fanout attribute set to 2 on net p_0_in39_in. Fanout reduced from 3 to 2 by creating 1 replicas.
INFO: [Synth 8-4618] Found max_fanout attribute set to 2 on net p_0_in6_in. Fanout reduced from 3 to 2 by creating 1 replicas.
INFO: [Synth 8-4618] Found max_fanout attribute set to 2 on net p_0_in3_in. Fanout reduced from 3 to 2 by creating 1 replicas.
INFO: [Synth 8-4618] Found max_fanout attribute set to 2 on net p_0_in0_in. Fanout reduced from 3 to 2 by creating 1 replicas.
In timing report the fanout it 24.
First I thought it would be connected to the funny renaming. But pushing definition of the signal outside the for loop (and makig it an array) didn't help.
One thing I find interesting: The signal is used as a clock enable 24 times and as a data input 2 times.
For me it looks like the two use cases are mapped to two different signals internally and only one of them gets the attribute attached to it?
@nupurs wrote:
@uncle_tim,
module Combiner
    input wire sysClk,
    input wire now,
    if (!lastNow)
end
endmodule
From synth report:
