onkarkk1
maximum delay from LUT ..
Can any one tell me what is maximum delay (ns) from the LUT of virtex - 4 fx -10 FPGA.
Thanks in advance,
regards,
Krishna Kishore.
eilert
Hi Krischna,
You will find these values in the static timing analysis report. (also found at the end of the *.syr synthesis report)
When you take a look at the times listed in the critical path (and the other paths too)
You will find entries like LUT2, LUT3, LUT4 wich all have the same gate delay. In addition you find the net delay for the routing from one of these LUTs to another in that list too.
 At the end is a total sum and in brackets the partitiial sums of the gate and net delays (called logic and route here)
You will recognize, that elements other than LUTs (e.g. MUXCY, MUXF5 etc.) have different gate delays, but the same for each gate type.
Also it can be observed, that the routing delay nowadays is almost equal or even greater than the gate delay.
Have a nice synthesis
  Eilert
onkarkk1
Thank you Eilert,
I found whatever you cited but i didnt find critical path is it seperately mentioned or we have to understand based on delays of the paths, it is showing only 3 paths delays(whatever big the design it is showing only 3 paths delays is it any constraint of the tool).. Please let me..
Thanks in advance,
regards,
Krishna Kishore
bassman59
Historian
Historian
onkarkk1 wrote:
Thanks in advance,
regards,
Krishna Kishore.
RTFDS.
-a
evgenis1
Advisor
Advisor
It is showing only 3 paths because this is the default value in ISE. If you go to "Place and Route" -> "Generate Static Timing" menu, and open "Process Properties" dialog, you can select different timing analysis parameters.
OutputLogic
