aleksazr
numeric_std, std_logic_vector to integer
code snipets:
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity TEST is port (
     addr : in integer range 0 to 31;
end TEST;
component TEST port (
end component;
DBUS : inout std_logic_vector(15 downto 0);
Inst_TEST: TEST port map (
addr => to_integer(unsigned(DBUS(4 downto 0))),
This is where I get the ISE error:
Actual, ParameterAssocOp, associated with
Formal Signal, Signal 'addr', is not a Signal. (LRM 2.1.1)
What am I doing wrong here?
gszakacs
Professor
Professor
You can't put the conversion right in the port mapping.  Fist define a signal like:
signal addr_i : integer range 0 to 31;
then make the assignment
addr_i <= to_integer(unsigned(DBUS(4 downto 0)));
Then map the port
  addr =>  addr_i,
-- Gabor
-- Gabor
gszakacs
Professor
Professor
Then map the port
  addr =>  addr_i,
-- Gabor
-- Gabor
aleksazr
Oh, thank you very much.
