vivek
over utilization of DSP blocks
Hello everyone.
I have synthesized a design in Vivado 2017.4.
The utilization report says that - over utilization of DSP blocks. I also see there is under utilization of the LUTs (< 1%).
Is there a way I can map the rest of the design using the LUTS?
I have attached the synthesis reports.
Thank you.
jmcclusk
Mentor
Mentor
Go to Tools -> Settings, and then select the project settings for Synthesis.     In the option list, set -max_dsp to the maximum number of DSP48's that you want to use.
OR
In the TCL console,  give this command (for 333 maximum DSP48's):
set_property STEPS.SYNTH_DESIGN.ARGS.MAX_DSP 333 [get_runs synth_1]
jmcclusk
Mentor
Mentor
OR
vivek
Hi @jmcclusk
Thank you! The FPGA I am using has 240 DSP blocks. Are DSP and DSP48 the same?
jmcclusk
Mentor
Mentor
yes,  DSP48 and DSP are the same.
vivek
Cool. Thank you.
It worked!
balkris
please refer this document for design closer
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2017_3/ug906-vivado-design-analysis.pdf
You can follow the steps below to generate a module level utilization report.
  1. Run Implementation and open the implemented design.
  2. Click Tools --> Report Utilization. This directs you to a dialog box. Click OK.
  3. This opens a window at the bottom of the Vivado IDE where you can see module level utilization.
If you want to export the module level utilization to a report file, you can use the below command in the Tcl console of Vivado:
report_utilization -hierarchical  -file location_of_the_report_file
To report the utilization of a specific cell, use the report_utilization Tcl command as follows:
report_utilization -cells sub_module_name
or
report_utilization -cells [get_cells sub_module_name]
Thanks and Regards
Balkrishan
