override register value in pnr
Hi all,
I have requirement of connecting a 32 bit register/parameter value to a submodule's input port and create the EDIF netlist.
Later in vivado pnr, I would like to override the value of the parameter/register with another value. Is it possible?
I know it may not be possible with parameter.
Is there any primitive which can provide a 32 bit value and later override the INIT value thorugh set_property?
SC
回复: override register value in pnr
Not sure if RAMB36 primitive is applicable in your case.
